Quote Originally Posted by ghosthunter
think of it this way.... Once you have your LPG kit installed, you will normally use LPG as your main fuel so you can keep your gasoline tank near empty (say keep 1/4 tank as a back up when your LPG runs out). That way you offset the weight of the LPG tank with the lighter weight of the near empty gasoline tank.
Thanks sir. So avoid ko palang magfill ng gas tank kung magpapalagay ako. Wala bang indicator kung gano pa karaming lpg ang laman ng tank? Gauge man lang? Saka regarding heat sa trunk pag bilad ang sasakyan sa direct sunlight, wala bang chance na magkaroon ng leak ang tank o kelangan avoid ko talaga pagparada sa non-covered spots?
