Page 207 of 211 FirstFirst ... 107157197203204205206207208209210211 LastLast
Results 4,121 to 4,140 of 4201
    #4121
    Quote Originally Posted by shibby75 View Post
    Seems that auto lpg is dying a slow death, not much user in the private community, also not much in the public sector. Andaming lpg taxi ang ma phase out ngayon, most of them are lovelife models.
    Pero im still sticking with my lpg toyota gli lovelife, converted it at 110thou km mileage and now its nearing 180k mileage. Thats 70thou km and 4yrs on pure lpg and problem free operation.
    Converted our 2007 Altis at 10,000kms. Mileage is now 115,000kms and it still runs well also; we warm up on gas then switch to lpg in optimal operating temp. Had to change the vaporizer once as well.
    Jul 2014
    #4122
    Quote Originally Posted by raspi View Post
    Sino na nakakuha ng color coding exemption sa QC for LPG? Ano requirements?
    http://www.autoindustriya.com/auto-i...ezon-city.html
    Jul 2015
    #4123
    good pm mga sir, ok pa ba mag pa lpg ng sasakyan?
    #4124
    I have converted to LPG a Nissan Sentra 1990 carbureted. It lasted only 2 years then my carburetor failed, stopped working with Gasoline, LPG only. I had to replaced the carb so I bi-fuel will be possible. It seems that LPG is too hot for the carburator parts.
    Posted via Tsikot Mobile App
    Jul 2014
    #4125
    Based on what I have read, carbureted vehicles are not suitable for LPG conversion as well as diesel engines.
    Aug 2015
    #4126
    Hi Sir,
    I'm new to LPG powered cars.
    May I know if we can fill it up by using LPG that we use in the house and is there an adaptor or kit that we can put on the LPG tank to fill up the car?
    Because there are no LPG stations in our province.
    Thanks.
    Hi Sir,
    Thanks.
    Mar 2007
    #4127
    Roundhead,
    You can't use your kitchen lpg. These are not well-refined for car use. If auto-lpg are not available in you immediate vicinity, maybe you'ii have to defer your upgrade plans.
    Jul 2013
    #4128
    cng and lpg vehicles are dangerous and is only recommended for third world countries. pls see: ajitvadakayil.blogspot.com oct 4, 2015. lpg taxi drivers suffer from a deadly lung disease.
    Either you believe it, or you dont.
    Jun 2005
    #4129
    ^ wow! dangerous kasi nakasulat sa blog.
    i also read sa isang blog that water kills.
    Jul 2013
    #4130
    Quote Originally Posted by sirkosero View Post
    mahigit 20 ang patay dahil kay lando. water kills talaga! and this is absolute proof!
    Nov 2012
    #4131
    Quote Originally Posted by pyramid00 View Post
    Dangerous kung me leak lang .... With proper install and proper maintenance no problems naman.
    Anyway my experience with lpg e good and bad i guess ... Have experienced leaks twice ... And all sorts of problems with my altis .... Although i can't blame all the problems to lpg kit as my car is aging na din.
    So many times ako na mismo nakakahuli ng problema.... Karamihan ng shop they know how to install pero pag sa troubleshooting medyo sablay na.
    Encountered problems as simple as wires na naluluto na pala ng engine ... Dami beses ko pabalik balik ... in the end ... I figured it out on my own.
    Anyway bye bye na ko sa Lpg .... Diesel na lang ako ngayon less problems.
    If you already are on gasoline and have the patience to maintain an lpg kit .... It might be worthit ... The system itself is not too complicated .... At least sa sgi kit na gamit ko .... Basically switching lang ng injectors lpg or gasoline.
    Mar 2007
    #4132
    Quote Originally Posted by Tediber Ang View Post
    Teliber, did you sold your lpg-equipped Altis?
    Nov 2012
    #4133
    Yes buti na lang ang dali sobra ibenta toyota .... 1 day ko pa lang na post ang ad sold agad but the buyer said papatanggal ata nya e.
    Sent from my LG-H950 using Tapatalk
    Sep 2016
    #4134
    Hello
    Hello; new member here. Would anyone know where I can have my LPG-converted Honda Civic EF hatchback 1991 RECONVERTED back to gas-powered? The conversion to lpg was done by SKN in Makati but they have long closed shop. Initially I could run it on both gas and lpg but had the gas shut off. I live in Muntinlupa area. hope you guys can point me in the right direction. I want the lpg system removed and reconverted back to original gas powered. Thanks and more power
    Sent from my LG-H950 using Tapatalk[/QUOTE]
    Jul 2014
    #4135
    Quote Originally Posted by Jojoj View Post
    Hello
    [/QUOTE]
    Try this http://xoomautogaz.com/
    They are located in Timog, QC. I believe they are the 'last man standing' in terms of Auto LPG Conversion.
    Mar 2007
    #4136
    Anyone converted a V8 with an lpg kit? Which kit did you use? Any problems / issues after long term use? Hope to hear from you and thanks in advance.
    Sent from my LG-H818 using Tsikot Forums mobile app
    Jun 2005
    #4137
    ^ ask mo yung xoomautogaz. May mga converted sila na mga exped, E150, F150.
    I think pati yung vice gov remulla ng cavite was a customer
    Jun 2006
    #4138
    Ok pa ang sgi lpg lovelife ko...travels 50km everyday
    Its now 6 yrs old and the only part repaired and changed was thehoses and lpg filter
    #4139
    If LPG was so good back then, why are there no more (or very little) LPG cars on the road left?
    #4140
    1. Service support is limited.
    2. People have adjusted to the cost of fuel which has been consistent, while the purchasing power of the Pinoy consumer is better. In 2008 we saw fuel hikes in crises levels which enticed a lot to use LPG.
    Our 2007 Altis still runs on LPG to this very day. It's been used by my brother and he's happy as the fuel cost savings is still good for him (as he's just starting up). The car still runs well on either gas or LPG and it's tuned by Xoom perhaps once a year.
    I've seen Xoom convert and E150 wherein the owner put two large tanks in the rear; That must have been around 130L to 150L worth of LPG that could be loaded.
Auto-LPG Conversion Thread
