Results 3,891 to 3,900 of 4200
July 3rd, 2012 03:51 PM #3891
Pag out of town gamitin mo rin pang luto...tipid na agad Sa mga kain Sa drive thru...Mas mapapabilis break even mo..
Sent from my iPad using Tapatalk HD
- Jun 2005
- 3,774
July 9th, 2012 12:17 AM #3892bakit ang mga taxi pag magpakarga ng lpg, lagi nakabukas ang trunk? wala naman dun ang filler hose
July 9th, 2012 12:55 AM #3893
July 9th, 2012 11:04 AM #3894
My LED indicator is quite "conservative".
When i'm doing 10km/L++ average in fuel consumption, here's the sequence of my LED indicator going off as against my trip meter which i reset to zero when i fill up my LPG tank:
1st LED goes off at the 80-100km mark
2nd LED goes off at the 130km mark
3rd LED goes off at the 230-250km mark
Low Warning (beep and blinking 4th LED) goes off between 250-260km mark
I can still go all the way to 500km without running out of LPG at this rate (have not encountered running my LPG tank dry). I usually gas up when i hit the 400km mark on my trip meter though.
July 18th, 2012 07:10 PM #3895
May problem yung LPG sa A33 Cefiro. After engine swap, the LED turned off. Checked the fuse ok naman. What could be the problem?
July 18th, 2012 09:46 PM #3896
July 19th, 2012 12:55 AM #3897
^Thanks. Called Macro recently but they only do service by appointment.
BTW I replaced my engine because of constant overheating. When the new engine was installed, there was still an unusual high pressure from the cooling system. And since the LPG kit isn't functioning, I asked the mechanic to bypass the "vaporizer". It instantly relieved the pressure from the cooling system (the upper rad hose is no longer bloated).
Been two months already and no overheat. My new engine seems ready for LPG. So I'll have the it reactivated asap. I hope the LPG's ECU is still intact.
- Jun 2006
- 1,139
July 23rd, 2012 12:46 PM #3898is it possible that the vaporizer is leaking lpg gas into the cooling system that can result to bloated or ruptured hoses?
August 1st, 2012 11:09 AM #3899
I thought of this before when i had some coolant flow problems but the guy at Greenfuel before said it wasnt the case (i changed my vaporizer though). I cured my coolant backflow problem by changing my radiator cap which was already busted pala.
I'm getting the itch to convert my 2012 Altis to LPG as well. I drove my LPG'd 2007 Altis yesterday and boy i really love the feeling of gassing up at P25/L and flooring the gas whenever i want to. :D
- Jun 2006
- 1,139
August 1st, 2012 10:29 PM #390029P per liter ngayon. Ano naman kya rason nila? Middle east turmoil? Di naman dun galing lpg.
Ford kasi... it needs a lot of TLC. ;) Kidding aside, I don't know if other turbo vehicles have...
0dometer problem
