Quote Originally Posted by eikichi View Post
Where did you have your fuel lines cleaned? Did they flush out the gas lines with a solvent? My car runs great on lpg but can't seem to keep the engine running when on gas. I already replace the fuel pump, fuel filter and distributor, cleaned the intake manifold, changed the spark plugs but the problem still persists. Parang nalulunod pag gas gamit ko hanggang mamamatay nalang yung makina. I was thinking baka yung fuel lines nagbara na din.
In my case, my metal fuel line between the tank and engine was clogged almost solid. I had my tank cleaned out but the metal fuel line under the car had to be replaced because the dirt inside has practically solidified. Before it was replaced, my car had a hard time maintaining high revs.
This could be the same with your car.
