Quote Originally Posted by aamd View Post
Hello all,
just to share.
i have an EU type filler.
i filled my LPG tank full and when i reached home, i heard a whistling sound at the rear and as i suspected, the filler was the culprit.
i immediately thrust the middle ball of the filler using a ballpen and voila, the whistling sound stopped.
Is this a sign that i have to change the filler?
My last LPG refill was again normal. No whistling sound.
Car: Outlander
Kit : Greenfuel
Installed: June 23, 2008
Savings since 2008: 55,209.36 pesos
hi aamd.
that happened to me before.
culprit: rust on the bearing ball on the filler valve that made the valve sealing ineffective. (some rusting occured after i lost my filler cap)(i suspect the gas boy did not cover it back).
my solution: after poking the filler valve, i sprayed some lubricant to fight rusting. then i got a new filler cap. (now, i uncover/cover back my filler cap to prevent losing it again coz it's not easy sourcing out a simple filler cap for lpg.)
never had the same prob anymore. my lpg kit was installed june 2008 at greenfuel too.
OT: bro, are you the one i met at speedlab before with the lpg-equipped rav4?
