Results 3,081 to 3,090 of 4200
- Jan 2008
- 29
January 28th, 2009 11:48 AM #3081
January 28th, 2009 12:41 PM #3082
hinde pa pwede i verify by changing the affected tension wire lang muna from other cars. kasi mahirap naman bumili ng bago then kung hinde mawala ang problem sayang ang pera. mahal pa naman ng high tension wires.
update mo na lang kami sir. thanks.
January 28th, 2009 12:47 PM #3083
Why not just use the original wire-set that came with the vehicle to test if the source is the high-tension wires currently in use?
- Jan 2008
- 29
January 28th, 2009 03:07 PM #3084
February 1st, 2009 12:48 PM #3085
question lang po:
1.0 has anyone tried using resistor type plugs? if yes does it improve your lpg performance?
2.0 how about iridium and other type of spark plug aside from the plugs recommended by OEM. may nakagamit na ba and does it also improve your lpg performance.
reason for the question:
im using lpg for almost 5 months now with stock plugs * 7K km running on lpg. the problem now is when the car is idling without AC, nag ddrop and RPM to the point na mag stall na yung kotse. during the first 3 months naman hinde ganito.
as recommended by greenfuel yesterday (alvin) try to replace the plugs with resistor type or the 6pbs type. i want to check with lpg user first para malaman kung may significant impact ba ito otherwise i will stick with the stock plugs. Thanks.
February 1st, 2009 04:02 PM #3086
Resistor plugs are also recommended on any vehicle that has other on-board electronic systems and as a rule, performance is in no way impaired by resistor spark plugs. Best to consult your vehicle specification booklet or search it via Internet.
Toyota Innova stock spark plugs uses (R) resistor type spark plugs (Denso K20HR-U11) because it has OB electronic system. Furthermore, I have been using one step colder Iridium (Denso IKH22 also resistor type) now running more than 10K++ kms with no hesitation and the engine runs a little bit colder too. I see not much difference using Petrol or LPG, but engine runs smoother on LPG
The only consolation of using Iridium and one step colder was extended life of the spark plugs, if you are comfortable with your stock plugs then just replace them shorter than normal schedule.
February 1st, 2009 06:32 PM #3087
- Sep 2006
- 106
February 2nd, 2009 09:22 AM #3088LPG prices keep getting higher. So the price difference between LPG and petrol keeps getting smaller. With the high cost of conversion, the ROI is getting longer. It seems it is now harder to convince other people to convert than it was a few years ago.
It is somewhat similar to what happened between diesel and gas. Years ago, their price difference is big, but not now.
You think that would also happen to LPG, that the price difference between LPG and gas would soon catch up to just a few pesos?
February 2nd, 2009 10:04 AM #3089
It'll get higher, but I don't know if it'll reach diesel-gas levels (and remember, diesel here is artificially cheap due to government subsidy). LPG has diverse sources, and is not reliant upon crude oil production.
The price inflation locally seems artificially induced. We'd been talking about the possibility of hoarding a few days ago, and lo and behold, the government has already caught at least one trader hoarding LPG canisters.
I'm sure there will be many more to follow.
February 2nd, 2009 12:11 PM #3090
* mile2 &GH : thanks for the advice. will replace the plugs with a step colder, check ko sa suking tindahan. update ko kayo. maraming salamat
Edsa is about 24kms long. So, 15b / 24 is approx 625m per km?
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
