Results 3,071 to 3,080 of 4200
January 28th, 2009 09:19 AM #3071
Almost all CleanFuel station have LPG, wondering why other players don't have?
January 28th, 2009 09:40 AM #3072
January 28th, 2009 10:15 AM #3073
thanks for the info. pinakamalapit na cleanfuel is sucat road , tsaka kung 19.95 laking mura nga, dito sa total alabang 20.65... Boooo talaga.
- Jan 2008
- 29
January 28th, 2009 10:22 AM #3074Just came from a day of diagnostics at Greenfuel yesterday. Medyo sumakit na ulo ni Tolits on how to make my Adventure works well again. Nagbaback fire kapag nag aaccelerate ako when using LPG. One of the possible cause he mentioned might be the hi-tension wire. Per tolits also, mine will be the 1st case of SGI na nakaka encounter ng ganitong problema. He used the tester in the diagnosis and found out that the 2nd wire shows "no reading". Will this be the main culprit? Just had my change oil, spark plugs and air filter last December. Tolits also replaced the injectors and railings.
For the meantime, petrol muna ginagamit ko since hindi talaga maganda response while using LPG. Please share your inputs. Thanks
January 28th, 2009 10:35 AM #3075
In my experience with high tension wires, they tend to fail after a year or so after installation. They either "leak" (failed insulation) or conductor breaks at the sockets by mechanical failure or corrosion.
Stock wires are still better unless you have fully upgraded your engine's ignition system.
January 28th, 2009 10:53 AM #3076
Mukhang malaki ang depot ng CleanFuel, saw Monday night at CleanFuel Shaw a private LPG tanker unloading its haul there.
Kung di lang ako nadala sa CleanFuel E. Rodriguez dahil sa oily lpg contamination baka kahit sa E. Rodriguez na lang ako nagpapa-refill, kaso kailangan ko pang dumayo sa Shaw Blvd para makaiwas sa oily lpg contamination.
- Jan 2008
- 29
January 28th, 2009 11:14 AM #3077i began to notice the problem on my 5th month after installation.
does it mean, im on my way on replacing my tension wires na?
- Jan 2008
- 29
January 28th, 2009 11:18 AM #3078
January 28th, 2009 11:20 AM #3079
- Jul 2008
- 102
January 28th, 2009 11:35 AM #3080Hi Mile2. Sorry for the inconvenience brought about by this shortage. Naguunahan lahat ng mga players for LPG since right now demand is high but supply is limited. For the Auto LPG industry I'm happy to hear that other stations have supply as this will keep the industry in good shape and still encourage other users during this crisis. Xoom is working with Petronas on improving the supply chain to minimize delays or 0 outs. Thank you for your continued support.
Thread was made nung 2018 pa po sir.
