Page 154 of 211 FirstFirst ... 54104144150151152153154155156157158164204 ... LastLast
Results 3,061 to 3,080 of 4201
    #3061
    Quote Originally Posted by rpxhost View Post
    Help"
    1. Since I used LPG, I left my gasoline tank dry
    2. One day, i loaded petrol but then it would not start. (the engine would start but no gasoline went to engine)
    3. What should I do???? somebody said the Fuel pump needs replacement.
    Any ideas?
    Nakakasisira daw talaga ng fuel system pag ganyan. One thing I like about the Greenfuel LPG-SGI system is that it automatically switches to gasoline every 20 minutes or so for about 5 seconds to help keep the fuel system running. Tsaka, I'm not sure about your LPG kit, but mine uses gasoline to start the engine and auto-switch lang ako sa LPG at 2500 rpm. Kaya di rin puedeng walang gasolina talaga yung fuel tank ko...
    #3062
    next time when i have the chance to visit them para ipa tune ulit, i will see to it na i vivideo ko na yung actual adjustments para next time ako na ang mag ttry. hirap kasi lalo na taga south pa ako.
    last time kasi i feedback na mababa ng konti ang mileage and my plug shows ok naman so they adjust (term nila sakalin) para mas lean ng konti. nag improve naman ang FC pero hinde consistent coz i dont drive the same route everyday.
    goodluck to ian.
    Aug 2006
    #3063
    Help"
    Any ideas?
    Stuck up fuel pump, if you know a mechanic who can do small mechanism repair you can bring it to him. I guess Raymond Sarol of MyMitsu can fix that, I saw him one time fixing a lancer servo. His shop was in San Juan - cell no. 0920-9252290.
    Aug 2006
    #3064
    Nasa Australia na pala si Ian, natuloy din sa wakas.
    Ian good luck...you're the man
    #3065
    bad trip, walang lpg sa total alabang hmmm hanggang kelan kaya ito??
    Apr 2004
    #3066
    I lost the plastic cap of my filler nozzle, installed under my rear bumper. It was after I gassed up at one of the filling stations along Mindanao Avenue in QC. I'm not making any accusations but I just found it suspicious that the filling station was selling brass filler caps. ;-)
    Any suggestions where I can get a replacement-- preferably plastic? Lorna of Greenfuel said that they don't have spares.
    #3067
    Quote Originally Posted by dragonmate View Post
    Please call Lorna again at 5359080
    Sadly Ian left for Australia to seek "greener" pastures BTW, he is the first Filipino auto-lpg installer among many applicants that has passed the stringent testing requirements of the Australian firm
    We will continue to train potential installers to be able to improve our pool of technicians and to provide better service to our customers.
    BTW, one of the reason for the current shortage of lpg is that stocks for the Philippine market were diverted to winter affected countries in Europe when Russian shut down the natural gas pipeline in the Ukraine
    Hopefully things would stabilize in the coming weeks
    Aug 2006
    #3068
    Bad trip nga, wala palaging LPG sa Xoom at Total North Fairview, dumadayo pa ako sa Clean Fuel Shaw Blvd.
    #3069
    yung sa akin, maikli yung thread kaya madaling natatangal, so when i went back to greenfuel pinapalitan ko ng ibang plastic cap with longer thread. so far everything i refill i double check para sure na nakakabit. di ko rin alam kung saan nakakabili na spare.
    Quote Originally Posted by bigMIKE View Post
    is there any open lpg refilling sa side niyo? wala pa rin kasi dito sa alabang area. and last question, do you have any update re your plan to open a branch sa south area? thanks.
    #3070
    cleanfuel at shaw has supply of lpg as of today.
    Aug 2006
    #3071
    Almost all CleanFuel station have LPG, wondering why other players don't have?
    #3072
    Quote Originally Posted by Mile2 View Post
    Not only do they have supply of LPG... they are cheaper than many of the other retailers too.
    Current price P17.95/L
    #3073
    thanks for the info. pinakamalapit na cleanfuel is sucat road , tsaka kung 19.95 laking mura nga, dito sa total alabang 20.65... Boooo talaga.
    Jan 2008
    #3074
    Just came from a day of diagnostics at Greenfuel yesterday. Medyo sumakit na ulo ni Tolits on how to make my Adventure works well again. Nagbaback fire kapag nag aaccelerate ako when using LPG. One of the possible cause he mentioned might be the hi-tension wire. Per tolits also, mine will be the 1st case of SGI na nakaka encounter ng ganitong problema. He used the tester in the diagnosis and found out that the 2nd wire shows "no reading". Will this be the main culprit? Just had my change oil, spark plugs and air filter last December. Tolits also replaced the injectors and railings.
    For the meantime, petrol muna ginagamit ko since hindi talaga maganda response while using LPG. Please share your inputs. Thanks
    #3075
    Quote Originally Posted by daneklog View Post
    In my experience with high tension wires, they tend to fail after a year or so after installation. They either "leak" (failed insulation) or conductor breaks at the sockets by mechanical failure or corrosion.
    Stock wires are still better unless you have fully upgraded your engine's ignition system.
    Aug 2006
    #3076
    Mukhang malaki ang depot ng CleanFuel, saw Monday night at CleanFuel Shaw a private LPG tanker unloading its haul there.
    Kung di lang ako nadala sa CleanFuel E. Rodriguez dahil sa oily lpg contamination baka kahit sa E. Rodriguez na lang ako nagpapa-refill, kaso kailangan ko pang dumayo sa Shaw Blvd para makaiwas sa oily lpg contamination.
    Jan 2008
    #3077
    i began to notice the problem on my 5th month after installation.
    does it mean, im on my way on replacing my tension wires na?
    Jan 2008
    #3078
    Aug 2006
    #3079
    What is the color of your spark plugs tip? If your spark plugs have these black deposit, you probably have oily lpg contamination on your tank. The only solution would be bleeding all your lpg out of your tank and change filling station.
    #3080
    Hi Mile2. Sorry for the inconvenience brought about by this shortage. Naguunahan lahat ng mga players for LPG since right now demand is high but supply is limited. For the Auto LPG industry I'm happy to hear that other stations have supply as this will keep the industry in good shape and still encourage other users during this crisis. Xoom is working with Petronas on improving the supply chain to minimize delays or 0 outs. Thank you for your continued support.
Auto-LPG Conversion Thread
