Page 286 of 420 FirstFirst ... 186236276282283284285286287288289290296336386 ... LastLast
Results 2,851 to 2,860 of 4200
    Sep 2006
    #2851
    sharing some info after my PMS:
    - one of the plugs are abit oily
    - air filters are oily
    - failed emission test (a week ago)
    Im worried bout the oily plugs and air filters. Is it because of oil contaminants from dirty LPGs? or engine problem? Ive done some research and oily air filters could be caused by PCV. anyone familiar with PCVs?
    I brought my xtrail to Greenfuel for tune up. Need to observe and check again my air filters and plugs... sana wag engine/loose compression problem..
    Aug 2004
    #2852
    PCV is possible... but it ccould be your LPG.
    Aug 2006
    #2853
    Quote Originally Posted by wesrex315 View Post
    I have experienced oily LPG contamination, but it only affects the spark plugs having black deposits and it does not affect the air filter. If LPG oily contamination all plugs will be affected and not only one, since all LPG injectors draw fuel from a single LPG rail (Valtek from GreenFuel).
    It might be PCV or one of your cylinder has blown/loose valve seal.
    Oct 2003
    #2854
    Question:
    How much peso do I save for every liter of LPG?
    From my estimates, every car has its own answer with said question. As for a 2004 Outlander. Here is my answer:
    GIVEN:
    Unleaded E10 Fuel Consumption: 7.10 KM/L
    Unleaded E10 Peso per KM: 7.5 P/KM
    Price of E10 Unleaded: 45.72 Peso/Liter (as of 26 October)
    LPG Fuel Consumption: 5.55 KM/L
    LPG Peso per Kilometer: 5.75 P/KM
    Price of LPG: 30.20 Peso/Liter (as of 26 October)
    SOLUTION:
    Compute for the Total Price per liter of LPG
    1. Get KM/L difference of E10 and LPG
    7.10 - 5.55 = 1.55 KM/L = KM/L difference
    2. Using Ratio and Proportion: Get the Price of the P/L difference:
    KM/L KM/L 5.55 1.55
    ____ = ____ = ____ = ____ = 8.43 P/L = Difference P/L
    P/L P/L 30.20 ?
    3. Get total price of LPG = LPG P/L + Difference P/L
    = 30.20 + 8.43 P/L = 38.63 P/L
    4. ANSWER: Get the difference between E10 P/L and No.3
    = 45.72 - 38.63 =7.09 Peso/L
    [SIZE="5"]Currently, I save 7.09 pesos for every liter of gasoline.[/SIZE]
    Apr 2006
    #2855
    Quote Originally Posted by aamd View Post
    Question:
    GIVEN:
    SOLUTION:
    KM/L KM/L 5.55 1.55
    P/L P/L 30.20 ?
    mas maganda kung per kilometer driven
    P45.72/7.10km=6.44pesos/km pag gas
    P30.20/5.55km=5.44pesos/km pag lpg
    in essence for every kilometer driven, P1 ang nasave mo, so kung 50km ang travel mo per day P50-ang savings mo a day.
    kung 10 km ka lang a day, P10 lang ang savings mo not worth it.
    Apr 2006
    #2856
    Question lang sa long time users ng LPG:
    baket pag sa TOTAL ako mag load ng LPG umaabot ako ng 39-40 liters, pag sa Petron ako mag load 32liters lang tops.
    edit:
    parehong from empty, as in ayaw ng umandar ng kotse unless gasolina ang gagamitin
    #2857
    Quote Originally Posted by jackfrost View Post
    The cut-off pressure for that "TOTAL" station is higher than at Petron.
    Dec 2007
    #2858
    edit:
    Sa akin baligtad.....
    Pag sa Petron(Buendia) ako : 37 - 38 liters
    pag sa Total(Kamagong) ako : 30 - 32 liters
    Depende po ata sa calibration/pressure cut-off ng pump nila......
    (pero yung consumption/mileage ko is pareho.....so lumalabas lugi ako pag dun sa Petron na yun ako nag pi-fill..)
    #2859
    not really worth it kung 10km (ave) ang tinatakbo mo everyday. more benefits pag ave mo is 50km and above. tsaka hinde nag roroll back ang lpg natin
    Quote Originally Posted by Redman7 View Post
    my experience sa total alabang until 36 li, sa cleanfuel 29-30 lang for a 40li donut tank. hinde naman ako lugi kasi kino compute ko based sa cut off pressure per station. try niyo i monitor on a week basis per station para more or less you get the same amount of lpg, then compare the mileage.
    #2860
    Quote Originally Posted by webmiester View Post
    Hi guys,
    What's the best LPG conversion kit for my 1.6 Lancer with EFI? Where do you suggest I get it, and how much will it cost me?
    Of course "best" doesnt necessarily mean "most expensive"
    hi anybody,
    i'm thinking about converting my ford escape 4x4 v6 engine to lpg and have been reading the previous posts regarding greenfuel and denso, open and closed loop...and have just gotten overwhelmed. Can anybody recommend the best lpg kit for a ford escape, where and at what price range? how long will it be until i see a return in the investment considering that fuel prices have gone down? help!
Auto-LPG Conversion Thread
