Results 1 to 20 of 4201
    Ask ko lang sa mga naka LPG, when it comes to changing the oil na what is your observation sa quality ng used oil? ganun pa rin ba kaiitim ?
    Feb 2006
    Hi mga bossing...
    Meron na bang LPG installer na nag aacept ng Credit Card...?
    o kaya Installlment basis...?
    Ang car ko po ay stock 94 corolla XE..
    Maraming maraming salamat po!
    I think I'm nearing the end of my quest. Just a few questions pa:
    1. My car doesn't have an oxygen sensor, so Greenfuel said that after installing an SGI system, they have to have the engine tuned at Speedlabs. After this tuning, will I now be able to maximize the benefits of an SGI system?
    2. Eroom offers a venturi mixer system with a computer box. I understand that this box will regulate the flow of the fuel. With this box, will this now approximate the benefits of an SGI system? (power and FC?)
    3. Has anyone tried both Eroom and Greenfuel's SGI? what are the benefits of one over the other? TIA
    Quote Originally Posted by chinacrisis View Post
    No, it just means it will run smoothly and well based on the conditions when it was tuned. Change the air pressure (like drive to Baguio) or have a very dirty air filter and the SGI system will not be able to adjust to the new conditions.
    Example: if during tuning, your air filter is dirty, the LPG system will be tuned to operate with the dirty filter. Change it with a fresh filter, your engine might end up running leaner than intended.
    Somewhat, but only at the low to medium range RPMs. At higher RPMs, the air intake restriction of the venturi itself will be more pronounced and bigger HP losses will happen. SGI system's advantage is that there is no air flow restriction to the cylinders.
    I think that has been answered many times before where the SGI-LPG system was compared to the closed loop Venturi Mixer LPG system.
  5. #5
    I have the EROOM kit installed. It's a closed loop system, but still based on the venturi mixer kit. The computer box or ECU is mainly for diagnostics only. It makes it easier to tune the LPG systems, since the parameters are read through the ECU. However, adjustments to air and fuel will still require manual turning of knobs and screws.
    The closed loop system is somewhere in between the open loop kit with emulator, and the SGI kit. So the kit's efficiency is better than other open loop kits. Siguro EROOM might approximate an SGI kit installed in open-loop setup (e.g. installing an SGI kit to a car w/o O2 sensor). A good tuning session should be the optimize potentials, regardless of kit you have.
    These differences are small for the average driver. Benefits of these kits are realized mostly during higher RPM ranges. So kung puro city driving ka lang na stop-and-go, kahit open loop kit, ok na. Pero kung puro long distance highway driving ka, better ang SGI.
    Quote Originally Posted by carlo21 View Post
    Hi mga bossing...
    pre, why not try giving the listed auto-lpg installers a call to find out? At least you will get the latest news regarding if they accept credit cards or not.
    But for now, I think SPEEDLAB accepts credit cards. They offer GREENFUEL auto-LPG kits.
    Feb 2006
    sir ghost eto po ba un?????
    871 Quezon Ave. Quezon City
    Tel. 376-4648, 376-4651
    email: speedlab*speedlab.com.ph
    TIA
    * carlo21
    yup yan yung speedlab...jan ako nagpapa change oil...MOTUL syempre! ipon mode lang ako para sa tuning nila...ganda magpa tune jan sa speedlab e...look for sir ferman nga pala kung punta ka jan
    __________________
    passion for fashion? craving for savings?
    visit MAI PASSION boutique at the fashion village * Tiendesitas
    Last edited by ghosthunter; August 14th, 2008 at 05:06 PM. Reason: correcting ferman's name
    Yes. Just look for Ferman or Sids.
    Aug 2007
    Good Day po ulit mga tsikoteers...
    I have a very good news to everybody...
    Due to some request form our inquirers...
    Our DENSO Service Center in Caloocan and Imus Cavite will now be accepting Auto LPG Installtions and Tuning.
    So for those who already have EROOM Close-loop Kits installed. You can now bring your units to these branches. NO NEED TO TRAVEL ALL THE WAY TO MAKATI.
    Also, WE are now accepting CREDIT CARD PAYMENTS starting next week.
    And finally, EROOM KOREA will have and will be bringing in the SGI system by end of September.
    Our Service Center can be found in:
    Denso Service Center (Caloocan)
    Unit D&E HGL Bldg. 2 554-C Edsa Caloocan City
    Tel NO. 3673351 look for Flor
    Denso Service Center (Imus)
    Km. 22 Emilio Aguinaldo High way, Anabu 1A, Imus Cavite
    Tel No. 06710546 look for Cathy.
    Soon our branch in ALABANG will also be accepting installations.
    Thank you...
    [SIZE=6]EROOM[/SIZE]
    [SIZE=1]for better environment[/SIZE]
    *Bigfootoz
    Any ideas on the pricing for your SGI kits? Assuming its for a basic 4 cylinder 1.6L EFI car.
    Mar 2007
    Huh? GH, you mean SpeedLab can do conversion jobs too?
    Quote Originally Posted by straker View Post
    yes.
    Mar 2007
    yes.
    Hmmm, the offer's getting tempting as ever. We have two shops that can take our credit cards!
    I wonder if Speedlab can offer BOTH the conversion and the tuning jobs as a package deal.
    Aug 2006
    The kit and the dyno tuning is priced differently.
    Quote Originally Posted by sequoia View Post
    I tend to change my motor oil every 5000km. My oil looks smooth. As for the color, it's still black.
Auto-LPG Conversion Thread
