Results 1 to 9 of 9
    ei,guys!iv been driving gas-manual cars d past 7 years (d last was a 98 rav4-im selling it,btw.any1 ntrstd? :lol: & i jst bought a 2000 Kia Carnival LS matic/diesel. i'd rili apprec8 any tips u can give for maintenance (wat oil & gas 2 use?every wen is change oil & filters [oil & air],shud i chnge d air filter 2 a racing filter,do i need additives,etc}. also, how do i drive dis thing thru flooded roads & up 2 how high can i dryv it thru? salamat po ng marami in advance :wink:
    Congratulations on your new Diesel Ride sir. :D This guide though written by Mitsubishi is applicable to all vehicle brands and makes both gas and diesels.
    Mitsubishi Periodic Service Maintenance Menu:
    The Periodic Service Menu serves as your guide for your Mitsubishi vehicle maintenance schedule. It indicates the type of service classification that will be done on your vehicle at certain kilometer readings.
    It is highly recommended that you bring your Mitsubishi vehicle to authorized service dealers for a periodic maintenance check up. Mitsubishi vehicle warranty is up to 50,000 kilometers for passenger cars/AUVs and 20,000 kilometers for Light Commercial Vehicles (LCVs). Complying with the regular periodic check up is more economical in the long run as it prevents early breakdown, thereby extending the life of your vehicle.
    1000 Km Checkup
    A. Operations after engine is warmed up
    Change engine oil and oil filter
    Check / adjust valve clearance (except for vehicles with auto?lash adjusters)
    Check / adjust basic ignition timing (petrol powered vehicles)
    Check / adjust basic idling speed and CO concentration (petrol powered vehicles)
    Check crankcase ventilation hoses (petrol powered vehicles)
    Check cooling system for leaks
    Check fuel system clamp for looseness and damages
    B. Operations inside the engine compartment
    CheckV-belts for cracks, fraying wear and adjust tension
    Check condition of distributor contact points
    Check condition of distributor spark advancer
    Check condition of distributor cap, rotor & condenser
    Check ignition cables for damages
    Check vacuum pump oil hoses for damages (diesel powered vehicles)
    Check condition and clean spark plugs (petrol powered vehicles)
    Check air cleaner element for clogging and damages
    Check fluid level in automatic transmission (including transfer)
    Check engine coolant condition & level
    Check brake / clutch fluid & power steering fluid level & condition
    Check / adjust brake pedal & clutch pedal for free play
    Check / top up battery electrolyte level and terminals for loose connections/corrosion; check battery clamp
    C. Operations under the vehicle
    Check suspension system for looseness & damages
    Check suspension arm ball joints for play & dust covers for damages
    Check drive shaft boots for damages
    Check steering linkage for damages & loose connections (including seals & boots)
    Check gear oil level in manual transmission (including transfer case)
    Check gear oil level in front & rear axles
    Check exhaust pipe connection / installation for gas leakages or damages
    Tighten underchassis bolts / nuts
    heck / adjust parking brake stroke & play
    D. Operations outside the vehicle
    Check brake hoses & pipes for leakages
    Check fuel hoses and pipes for leakages
    Check tire wear, tread depth, inflation pressure, center cap and tire valve cap
    Check windshield wiper nozzle and wiper blade
    E. Electrical operations
    Check condition and function of all exterior lamps
    Check condition and function of all interior lamps
    Check instrument panel lamp
    Check all instrument panel meters and gauges
    Check function of all power windows, power mirrors and power door locks
    Check front/rear wipers in all ranges
    Check horn
    Check warning buzzer
    Check power antenna
    Light Checkup (5k, 15k, 25k, 35k, 45k, 55k, 65k, etc...)
    Check V-belts for cracks, fraying wear and adjust tension
    Check intake air & turbocharger oil hoses for damage (vehicles with turbocharger)
    Check radiator hoses for damages & proper connection
    Check / adjust parking brake stroke & play
    Check fuel hoses & pipes for leakages
    Check horn
    Check power antenna
    Regular Checkup (10k, 30k, 50k, 70k, 90k, etc...)
    Check/ adjust basic ignition timing (petrol powered vehicles)
    Perform emission test
    Check / clean condition of throttle body
    Check air cleaner elementfor clogging and damages
    Check adjust brake pedal & clutch pedal for free play
    Check suspension system for damages & looseness
    Lubricate suspension arm, steering linkage & propeller shaft with grease fitting
    Rotate tires
    Check / clean brake pads, shoe linings, discs for wear, brake & drums for wear
    Check horn
    Check power antenna
    APPLICABLE ONLY EVERY 30,000 kms.
    Change gear oil in manual transmission (including transfer case)
    Change gear oil in front & rear axles
    Repack wheel bearings (Check condition and recommend replacement if necessary)
    Heavy Checkup (20k, 40k, 60k, 80k, 100k, etc...)
    Check basic ignition timing (diesel powered vehicles)
    Check/ adjust basic idling speed and CO concentration (petrol powered vehicles)
    Check the choke mechanism and linkage
    Check gas recirculating system (petrol powered vehicles)
    Check body condition for damages (underbody coating & body paint for corrosion damages)
    Replace contact point and condenser
    Check intake air & turbocharger oil hoses for damages (vehicles with turbocharger)
    Check operation of crankcase emission control system (petrol powered vehicles)
    Replace spark plugs (petrol powered vehicles)
    Inspect condition of fuel injectors
    Check/ clean condition of throttle body
    Replace air cleaner element
    Replace fuel filter
    Check/ adjust brake pedal & clutch pedal for free play
    Check/ top up battery electrolyte level and terminals for loose connections/corrosion; check battery clamp
    Check suspension system for damages & looseness.
    Rotate tires
    Check front/rearwipers in all ranges
    Check horn
    Check power antenna
    APPLICABLE ONLY EVERY 40,000 kms.
    Replace engine coolant
    Change automatic transmission fluid (including transfer) and replace automatic transmission internal / external filter
    Change brake / clutch fluid & power steering fluid
    RECOMMENDED BETWEEN 60,000 kms and 80,000 kms
    Replace engine timing belt (Except vehicles with timing chain)
    :D
    Dec 2002
    there are lesser problems in driving a diesel thru floods, kasi you don't have distributor, ignition/spark plug wires, spark plugs to contend w/
    as for the a/t, ok din yun kasi sealed yung transmission mo, so h2o won't get it, kaya gas and breaks ka lang, just be sure to step on your gas a little kung mababa menor mo para hindi tumirik
    How much are you selling you rav4?
    Tignan mo how high the dipstick and the breather of the a/t is. Minsan nipple lang ito on the side of the tranny that needs to be extended with a rubber hose.
    Dec 2002
    oops... tama si otep
    nakalimutan ko yun breather ng a/t :oops:
    sir roydok,
    tagal ko binasa yun ah :D tnx
    sir otep,
    how do i know w/c 1s d breather? :oops: (sori po.i just dryv kc,dnt knw d parts..hehe)
    boss hybrid,
    tnx also,il pm u d details & d price :mrgreen:
    wulf,
    Just look at the transmission, if you see any tube or hose that just goes nowhere (ends in the atmosphere) then yun ang breather.
    I followed the breather on my brother's Sentra. It stopped beside the brake master cylinder.
    1 piece of advice--stay away from signet edsa mandaluyong...(kia & mazda dealer) nag-canvas ako kanina ng oil filter binigay nila sakin replacement!! orig daw yun e wala naman nakalagay na kia brand!! nakikipagtalo pa sakin yung tao dun..pinakita ko nga yung pinagpalitan ko dati...hehehe tameme cia...dunno if they also do this to their mazda vehicles just sharing peeps....:?
    Yung orig na parts ng Kia usually may hologram sticker. Kung hindi naman, may high quality barcode sticker. Just sharing.
any tips 4 1st time matic/diesel user?
