Results 111 to 118 of 118
August 20th, 2011 12:48 AM #111
August 20th, 2011 09:47 AM #112
The impurities and particulates in waste vegetable oil make it unsuitable for use in CRDi engines, even if you filter it.
It might be possible to strain the oil with a 1-micron filter, but even then, there's no assurance that the contaminants and/or water content will not damage your pump and/or injectors.
Best to convert it to Biodiesel, but I've heard that this may have an unwanted effect on the valves of ordinary diesel engines if you use 100% Biodiesel.
August 20th, 2011 10:18 AM #113
- Jun 2024
- 4
June 20th, 2024 12:12 AM #114hello bonjour, i am so sorry for reviving this 10 year old thread...
firstly i am not lucky enough to be a Pilipinoe.. i am Canadiano.. i live in Tacloban city and i have full intentions to buy a 2012 toyota Fortuner next month kasi they dont exist in my malamig country.. and for nearly 20 years ive fantasized about driving a diesel and using waste cooking oil.. moving around your beautiful country at zero cost.. (kasi i grew up a palaboy in Canada).. i believe the best cars (that need zero modification) is Mercees 300D, 240D and finally 200D.. 1984.. however.. if i start egine and cut engine using only WVO will form Caramelization inside the cylinder and on top of the piston so a conversion kit is heavily advised... so.. since i absolutely need a wvo (conversion kit).. i dont REALLY need a 1984 mercedes which uses IDI.. indirect diesel injection..so.. F it.. ill get the 2012 toyota Fortuner here in Leyte.. it has a D4D engine.. which uses CRDI.. common rail diesel Injection.. so finally here is my question.. is there a garage somewhere in i dont know.. Luzon maybe that installs a generic waste cooking oil kit.. beause the kits sold online are buang prices.. 2000$us... .. i am positive there is a mechanic somewhere in this super intelligent country that can do this at a much lower cost... most of the parts are universal. a long hose from engine block to the boot (trunk in my igit country..).. an aluminium secondary tank to store the wvo (waste cooking oil).. a switch to change fuel to engine from wvo to diesel and reverse.. the only part that i imagine would cost anything is the relay for the switch.. do any of you know a mechanic in your brgy that can get all these simple parts and duct tape everything into my first ever SUV ???
salamat and amping
June 20th, 2024 10:17 AM #115
I don't know.... The fact that even if you only use quality straight Diesel fuel from reputable gas stations does not exempt you from running into occasional fuel system issues like carbon buildup and clogged injectors. Much more if you use a fuel source which aren't made specifically for internal combustion engines.
Maybe if I was using an old-school, non-CRDI engine, I'll probably consider WVO as a viable fuel source. However, most modern CRDIs and emissions systems above EURO II are just too unforgiving in terms of fuel quality, IMO. They will run on WVO sure, but long-term engine durability and reliability may not be what one might expect. And if issues arise, the high-pressure fuel system (pump, SCV, injectors) are also very expensive to service, repair, or replace. The penny saved on fuel can quickly translate to a significant repair bill later.
- Jun 2024
- 4
June 20th, 2024 12:01 PM #116
wow thank you for your very informative reply, should i stick with the old 80's Mercedes to have this car last the longest, but im positive if my umm driveshaft ? snaps again like it did it on my probe GT back in Canda.. my entire brgy will hear me screaming and swearing in Quebecois if i try to pull it out of the transmissission... i fully intend to take a few carferry rides from leyte to Cebu... there is a Canadian fast food burger place there called Harveys that i miss so so much.. and during that boat ride. if im permitted, id like to sit in my vehicle with the aircon on.. problem with that is that i am a cheap b4stard... and to run AC the motor nees to be running... but if i have wvo.. i wont care
may i ask.. how long till i actually see engine damage from WVO usage ? 5 years ? 10 years ??? by then i will most likely have that bobo Canadian electric car.. the umm Tesla ???
- Jun 2024
- 4
June 20th, 2024 05:27 PM #117I as a Canadian environmental list completely view with you and yes your post might have been before or after typhoon yolanda regardless even McDonald's in the Philippines surrenender all their used cooking oil to the police force of the Philippines so they are driving on used cooking oil if you are not aware
- Jun 2024
- 4
June 20th, 2024 10:14 PM #118worth mentioning.. that diesel is a gasoline production byproduct.. and WVO has alot less emissions than actual diesel... so.. if im ever caught driving wvo.. i expect a sweet postcard from EURO II thanking me for my efforts.. .. furthermore.. all jeepneys in the Philippines were or are diesel since the US occupation... if my wvo is bad in anyway.. it is a tiny drop compared to the black smoke coming from Jeeps i saw on Mcarthur hwy in Caridad Cavite..
Ah ok. So Wala pa Lang locally released na delicą dito. Pinapakyaw kasi Ng mga outdoor lovers...
Mitsubishi Philippines
