Results 41 to 50 of 84
November 11th, 2004 02:45 PM #41
Bro!,
just get a Vitara and have a good roofrack placed (di ko alam kung may compatible na THULE para jan)...kayang-kya i-drive ni nini 'to.
pa-test drive na lang pagnakakuha ka na....
November 12th, 2004 10:19 AM #42
bro,
baka nga maunahan mo pa ako makabili eh. ako nalang pa test drivin mo. para kung palpak, i'll get the other choice.
November 12th, 2004 12:26 PM #43
Suzuki Vitara JLX (1994 and 2004)
Lots of aftermarket parts for making your Vitara look tough and rough(Calmini.com & Rocky-road.com). There are parts available locally and can be purchased everywhere (Links banawe, Fronte banawe, Pilhino, etc)
Upside:
1. High ground clearance
2. Compact and easy to park
3. Strong engine (power to weight ratio)
4. Auto Hubs Fr(4L, 4L)
5. Sturdy underchassis/suspension
6. Approach and departure angles(RTI)- OK
7. Aftermarket parts availability
8. Full-frame chassis with manual transfercase
9. Compubox located high(for flood fording)
Downside:
1. Weak aircon
2. Prone to warp door sidings
3. OEM suspension - bouncy
4. Expensive spare parts
5. Slow acceleration if matic
6. Insufficient leg room space at rear.
7. Low amp alternator rating
Fuel economy - Depends on the driver & frequency of maintenance. Mine is around 7 to 9km/Lt City & 11 to 13km/lt Highways.
* Most common defect of Vitara 96 and below are:
(check the following if you plan to buy one)
1. Fuel pump
2. Power windows/switches
3. Power steering gearbox
4. Power steering pump
5. AC Compressor
6. Alternator
7. Door sidings
8. Radiator
9. Water pump
*Note: The post is not in direct in comparison with Terrano. I'm just posting the advantages and disadvantages of the vehicle per se over other 4wd vehicles in the market.Last edited by mikaztro; November 12th, 2004 at 08:21 PM.
November 12th, 2004 12:46 PM #44
iMo... nagagandahan ako sa terrano matagal na... pero sa dami ng nakakausap ko na may ganito, ang feedback nila ay mabagal daw... and mas maraming nagpupush sa akin na vitara nalang ang kuhanin dahil mas maganda daw ang performance nito kesa sa terrano.
tanung ko nalang dito gasolina kasi ang vitara eh... ang terrano may diesel kaya mas matipid.. hmm....:D
November 12th, 2004 01:10 PM #45
We had a Terrano before and the gas engine is a gas guzzler. The diesel engine is pathetic. You need to install a Turbo in it to have some push. The Terrano though has good looks and styling plus a lot of leg space and compartment.
November 12th, 2004 01:29 PM #46Originally posted by mikaztro
...4. Free 4wd hubs(true 4x4(4lo & 4hi))
5. Sturdy underchassis/suspension...
Di ba mas matibay ng rear leaf spring suspension setup kesa sa OE bouncy coils comparing both on solid diff setups. And also front torsion bars on wishbones can deliver more comfort than macpherson strut type of Vitaras.
November 12th, 2004 04:24 PM #47
If you want to go the extreme route, the Vitara is the better choice. If you want to go to the edge of the world, the Samurai will do it.
tricky
- 10,620
November 12th, 2004 04:31 PM #48eto na ba talaga ang pinapipilian mo?
well i pretty sure you could get a Landcruiser 40 series with this kind of cash,
ECG's 40 is under 400K
its pretty mean with its 33's, all the knobs, switchses are working with AC pa, reverse shackles , Mechanical Winch
as for the ride you spend pa to convert the leaf into coil springs
November 12th, 2004 06:05 PM #49
Ungas,
What mikaztro meant siguro was auto hubs for the front as what you mentioned. Also just a clarification, hindi MacPherson ang front IFS ng Vitara. The front struts and coil springs are located separately from each other, the former being more lateral.
HTH.
November 12th, 2004 06:48 PM #50
Oh ok, I stand corrected front strut IFS for Vitara. But still, front torsion bar springs with wishbone arms offer more comfort. :D
