Page 1 of 2 12 LastLast
Results 1 to 20 of 80
    Jun 2018
    Tulungan mo ko pare, si Kona o Vitara o Civic?
    No contest out here. It's the Civic.
    Quote Originally Posted by Cky View Post
    "what do you need the car for?"
    Mar 2017
    Civic, if you do not need the higher ground clearance of the other two.
    Quote Originally Posted by AllenR View Post
    If you want ground clearance, get a pickup truck. If you need something that drives well plus with good ground clearance, spend a bit more and get the XV. Subaru is on sale this June (1.3M for the base XV).
    Mar 2017
    I'm very tempted by the XT on sale (200K off), actually.
    BTT: Civic for city driving, but a with full grown malamute inside... maybe, but better check the space before buying.
    You should get the XT. There will be no XT model on the next generation Forester.
    If carrying a big dog, I would suggest the Forester over the XV. All Forester models are on sale (200k off).
    Jun 2018
    Thanks for the tip Sir Egan101
    The Forester has enough room for a big dog.
    Sep 2014
    Try mo vW Golf GTS para maiba naman
    Jun 2018
    Sir AllenR 185 mm for vitara 170 mm for kona and 133 mm for civic... halos dikit na...sabagay sa baha iba na ang mataas (kahit konti) thanks AllenR
    Jun 2018
    Daily driver dr. d...mostly city driving and weekend getaways with a malamute inside
    if the malamute will sit beside you (strapped like any other passenger, and i am not even sure if this is legal. heh heh), any of these cars will do.
    but if it needs its cage...
    measure the cage, sir, and then go see the kona and the vitara, and see if the measurements can be accommodated. if dog is still "small", make allowances for growth (of dog and of cage).
    Jun 2018
    dr. d no cage...just like sa picture ni Egan101...lito lang ko sa dami ng features ng vitara...at the same time nanghihihayang ko if di ko makukuha civic... haaaaaaaaaaaaaaay
    in that case...
    vitara.
    or crv, para ka-dugo ng civic.
    Take the Vitara for a test drive and also the Civic. I suggest you also give the Subies a test drive.
    If you really want a crossover, take the Civic out of your choices. In terms of capability, I don't think the Vitara is up there with the XV.
    Sep 2006
    I'm for civic, pero panu si canine? Haha
    try visiting the dealerships. i went to nissans and isuzus but missed fords. i easily ruled out the terra [emoji28]
    FOCUS
    May 2011
    FOCUS
    Na test drive nyo na po ba yung terra? Ano pong basis nyo na ruled out agad ang terra? Pra lang maliwanagan din
    Sent from my CPH1609 using Tapatalk
    Quote Originally Posted by alsil28 View Post
    I think the TS is looking for a vehicle with a more car-ride feel over something that drives more like a pickup.
Vitara GLX vs Kona vs Civic 1.8E CVT
