Results 11 to 20 of 224
- Sep 2013
- 375
February 6th, 2014 02:03 AM #12Does the gls model of mirage have ABS already?
February 11th, 2014 07:51 PM #14
February 21st, 2014 12:17 PM #16
Honestly the all new i10 1.0 S 'AT' is just 588K ;)
Looks cooler inside and out than either the Mirage nor Wigo. But then the Mirage still has better specs.
- Sep 2013
- 375
February 21st, 2014 12:42 PM #17Having dilemma between mirage Glx At or Wigo TOTL AT? and is the engine by daihatasu good enough? Thanks guys!
February 21st, 2014 01:00 PM #18
February 21st, 2014 01:21 PM #19
In the class, none of these engines have the MIVEC beat for the combination of economy and power. I believe Hyundai will have the best package, but I have my doubts that they can beat the Mirage's efficiency. Same with the Wigo, as it uses a mere 4-speed AT, and the body is not as well optimized for aerodynamics as the Mirage. Check out the grille, for example... gaping grille opening with less grille block than the Mirage. Then there's the boxy profile and the Indonesian developed body work. This is opposed to a the Mirage, which has an incredibly low drag coefficient and the tapered slope at the back needed for smoother airflow.
The Wigo can definitely hit over 20 km/l with the manual... but if it doesn't get at least 25, that'll be a disappointment.
- Sep 2013
- 375
February 21st, 2014 01:35 PM #20
I don't know why people continue to try and take Kennon Road from Rosario. Its perpetually being...
2023 Toyota Wigo
