Results 21 to 30 of 131
- Sep 2003
- 193
February 24th, 2005 01:48 PM #21The new generation CRDI engines uses higher fuel pressures that no clogging would occur in the nozzles. Compare to the first generation CRDI, the fuel pressure is about 3 times higher. So clogging nozzles is not a problem.
Unfortunately, the D-4D does not have the maintenance free particulate filter na standard equipment sa european diesels. With an EGR system soot will accumulate sa intake manifold. Plus a PCV that doesn't have an oil separator, vaporized oil could enter the intake manifold.
This could be the reason why the power of the D-4D engine might have been toned down to 102ps. This would lower the tendency to have vaporized oil going into the manifold. Less HP less Blow by gasses entering the crankcase then less chances of vaporizing the oil to go out with the PCV.
Nevertheless, the D-4D has a lot of potential in further increasing HP by adding an intercooler.
INNOVA for me.
Rodski
- Feb 2005
- 165
February 24th, 2005 09:27 PM #22Thank you for all your opinions... mostly Innova pala prefer nyo. =) Ganda kc ng Innova. hehe
Sbi ng Isuzu, the free powerwindow, powerlock, cd tuner etc is until end of March lang pala.
Have you guys tried the Innova already? I'm still not sure which auto to get. The Innova is relatively new and isn't it a bit lowered? Parang feel ko ndi kaya pag baha. =) Thank's again...
February 24th, 2005 10:27 PM #23
ako biased.. naka revo kasi ako and toyota lahat ng naging cars namin hehe...
i'd go for the INNOVA ..
for me, dalawa lang lamang ng crosswind, SUV look and fuel efficient ang diesel nya..
sa innova, coil spring lahat ng suspension kaya better ang riding comfort nya, yung flex ride ng crosswind eh matagtag pa rin yun compared sa coil spring ng innova..
i don't think na magiging problem ang parts ng INNOVA, the D4D diesel is the same with 2.5 hilux and 2.5 hiace kaya meron common parts .. sa iba pang parts, wala ako malaala na mahirap maghanap ng parts sa mga previous toyota vehicles..
tahimik ang diesel ng INNOVA.. so mas relax ang driver at mga passengers lalo na sa long drive..
regarding sa quality ng diesel fuel, bumili sa mga sikat na gas station, huwag sa mga new players na ngayon mo lang narinig..
and, lahat ng freebies ng isuzu eh pede mo naman mabili in the future pag meron ka na budget.. once you buy the crosswind, wala ng solian hehe ...
go get the INNOVA hehe
- Sep 2004
- 65
February 24th, 2005 10:31 PM #24Originally Posted by jim
I agree na malakas ang hatak ng innova d-4d but the noise is just normal as other diesel engine especially if you are in quiet place... lalo na pag open aang hood....
BR,
epic ;)
- Sep 2004
- 65
February 24th, 2005 10:37 PM #25Sabi ng casa, Innova can withstand 24" of flood water, cause the location of air intake ng air filter plus the ECD or CRD engine computer ata ay located in a higher position inside the van so hindi ito madali mabasa.... yan ang sabi saking lang
BR,
epic ;)
- Dec 2004
- 430
February 25th, 2005 01:40 AM #26straywolf no brainer na yan innova j ! D-4d is common rail direct injection against ahh direct injection
I've tried to sit in the innova and tried to ride it its not vibrating compared to a crosswind
ako sensitive ako pag sumakay ako sa diesel nahihilo ako
dati yung crosswind xuv sumakay ako naka idle nahilo ako
sa innova sumakay ako ng idle hindi ako nahihilo kasi not vibrating ang kotse
miske i rev mo pa up to 3k rpm hindi nag vivibrate ang kotse and tahimik sa loob.......
mag innova ka na at tingin ko resale will be higher compared to a crosswind
February 25th, 2005 03:49 AM #27
I'd choose the innova over the Crosswind..
OT: mivec na pala ang Grandis.
February 25th, 2005 11:15 AM #30
Innova na din for me if I had to chose between the two.
Otherwise, I'd just buy something used.
