Page 2 of 2 FirstFirst 12
Results 21 to 40 of 58
    IMO... kung sagot ng company fuel mo... Petrol
    kung sagot mo... Diesel
    Kung plan mo ibenta 5-10-15 years later... mas maganda resale value ng Diesel, and let's just say in 10 years pareho market value nila... Mas madali pa din ibenta Diesel.
    As for the "mas malakas ang diesel na makina" - well it's bigger 2.0 vs 2.8
    Innova spec sheet...
    Engine Type
    2.0 Liter Gas, 4-Cylinder, In line 16 Valve, Double Overhead Camshaft
    1,998L
    Maximum Output 136 / 5,600
    Maximum Torque 183 / 4,000
    2.8 Liter Diesel, 4-Cylinder, In-Line 16 Valve, Double Overhead Camshaft (Variable Nozzle Turbo Charger w/ Intercooler)
    2,755L
    Maximum Output 171 / 3,400
    Maximum Torque 360 / 1,200 - 3,400
    I'm not a car expert, pero as expected, almost double torque nung diesel at lower RPM pero the petrol version will give you power until 4k!
    Max HP din ng petrol version is at 5.6k...
    So the way I see it... if you love high revs... the petrol version will be more fun for you...
    The Innova is one of those cases where the diesel outshines the gasoline in every way, tapos 100k lang difference sa price so the diesel is always the better buy.
    The petrol version doesn't "give you power until 4k", more like it only gives you power at 4k and above.
    And most Filipino drivers don't even drive above 3000 rpm. Kaya mas bagay ang diesel. Diesels work better at low revs and then run out of breath after 3500 rpm. Gasoline engines usually need to be revved above 4000 rpm to get going quickly.
    Diesel or Gasoline bro?
    Sir, Diesel po.
    Long time no hear. Wala ng UFC moments, heheheh.
    Salamat po.
    Quote Originally Posted by RomeoAlpha View Post
    Is a 2013 innova e AT, a good biy at 699k? Thanks.
    From CarGuide.... Dec. 2013...Innova 2.5 E..... Diesel....P 992,000(M/T) P 1,057,000 (A/T)...
    I'd say the price should be okay (P358K depreciation in 4 years)....
    Huwag lang sobrang taas ng milyahe at laspag ang kaha,- okay iyan....
    Mga gulong bro,- makakapal pa ba? Baka palitin na rin....
    Tsaka kung mahihilot mo pa ng P50K or P20K na bawas sa presyo,- okay iyan... Gamitin mo bro ang iyong persuasion and charm.....Pero kung labs mo na talaga,- hingi ka na lang ng P5K bawas for detailing....
    Salamat sa input Sir.
    20k to 50k nganpo range ng discount na ineexpect ko. Sana mahilot. Hehehe. Crossing fingers.
    Galingan mo bro ang awit at masahe,- bibigay iyan...
    Good luck and Enjoy!
    Salamat sa mga input Sir. Hanap hanap ulit. di na ako amgofcus dun sa nakita ko na innova more than 100k na ang kilometrahe eh.
    1st choice ko 2013/14 innova e AT pero worst comes to worst, 2016 1.5G Avanza AT or 2015/16 Ertiga na TOTL AT din.
    basing only on the given info, it is a good buy but you still have to check the overall condition. if you are lucky makakahanap ka pa ng mas mura
Toyota Innova: Gas or Diesel
