Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    All 4x4, All at same price, same mileage... What would you pick?
    May sabi mas maganda strada and ranger kasi may Turbo, totoo ba?
    May sabi mas matipid kung walang turbo? totoo ba?
    Feedback pls...
    Thanks
    Lahat naman sila may turbo.
    And which Strada? The real 'new' Strada (coming soon) or the current ones we have here now?
    Turbocharging is just one aspect of fuel economy. You'd have to take into account weight, aerodynamics, gearing, tires, driving style etc.
    strada. dami spare parts since it shares a lot in common with other mitsu vehicles.
    Quote Originally Posted by OTEP
    Hi, ang sabi nila the old Hilux SRJ or SR5 has no turbo daw. I'm referring to the old strada with 2d56 engine.
    Otep, do you mean mas makakatipid sa fuel pag may turbo?
    Btw, according to the VEHICLE'S MANUAL, at 60T km odo reading, dapat we should change our timing belt/ chain na, do you do that? Or antay masira ang belt/chain?
    Kasi according to mechanic, di lang timing belt/chain ang papalitan, pati daw mga tension bearings.. etc..
    Turbocharging is a method of acheiving more power without a drastic increase in fuel consumption. It does not mean that a turbocharged 4d56 will be more economical than a normally aspirated 4d56. Rather it means that the turbo 4d56 is making more mid and top end power while still maintaining the fuel economy of a NA 4d56 when off-boost (e.g. low rpms).
    If you wait for the timing belt to break, better buy a new engine. AFAIK, almost all new engines are of the interference type. Meaning if you break the belt, you also run the risk of bending the valves, scoring the pistons, etc.
    Timing belt replacement is part of maintenance. However, since you've already dismanted the front half of the engine, it is also a good time to put in new tensioners and a new water pump instead of having to dismantle again in the future (preventive maintenance).
    The old Hilux did not have a turbo. It made around 80bhp? Test drive one first. A Strada with 99bhp feels underpowered to some people already.
    Hi, do you mean the 2003 strada has a 99bhp ?
    I'm now driving a 2004 revo 2.4 diesel engine with 32K mileage,ok naman for fuel efficiency medyo mabagal lang ang pick up, it so happen a friend offered me to swap his 2004 Strada 4x4 (with 55k mileage), pero add pa daw ako ng 250K. At first ok ako, but came across a mechanic, sabi nya, I have to make preventive maintenance when the strada reaches 60T mileage (which Otep say is true). kaya nag-dadalawang isip ako. What you think guys?
    Is it worth the swaP since add pa ako 250K? Ano kaya ang disadvantages owning a strada than a revo? I never drove one pa.
    Yes, 99 bhp yung mga Strada. Test drive mo muna.
    Disadvantage? Mas matagtag sa REVO, you have nowhere to put your stuff except the passenger cabin, tight backseat, harder to park because its long and the rear visibility is not that good.
    Advantage. All terrain. Very robust. Interior is nicer than a REVO's.
    I'm just not sure if it's worth Php250k.
    Mga Php5k lang naman magpalit ng timing belt. And you can do it at around 80k kms naman. Maybe the manual said 60,000 miles which is roughly equivalent to 100,000kms.
    Sir Otep, maganda ang strada kasi all terrain and robust, very true talaga.
    Matagtag? Bouncy ride? For you sir, would you swap plus 250K? Bihira naman ako nagkakarga kaya my friends told me to stick out with Revo, kasi pang pamilya. Yun strada, maganda pang porma and hill climbing (which I don't do).
    Among the three... the Ranger has the highest hp & torque output (117hp).
    Good acceleration though the tranny is really rubbery & trucklike. But still it is a good vehicle overall.
    Kung natotolerate mo naman ang bouncy ride ng REVO, kaya mo na din siguro ang sa Strada. hehehe. I drove a REVO in Baguio, mas masarap sumakay ng MB100.
    Dati inisip ko din mag-pick up. Yung mga last remaining Mazda B-series ng FMC. Kaso wala akong mapapaglagyan ng gamit kapag may trips, nag-grocery, etc. Kaya van na lang kinuha ko. Wala din naman ako ikakarga sa likod ng pickup. Bihira lang.
    Pero ngayong may iluluwas akong double deck bed from Bulacan, sana may pick up ako. hehehe. Hindi kasya sa Pajero.
    Hindi ko lang talaga sure kung worth Php250k.
    Aug 2006
    get ranger, smoother engine and suspension..
    Mar 2005
    useless naman talaga cargo area ng pick-up eh walang mailagay. waste of space. imagine dala-dala ko araw araw na strada, kalahati ng consume ko space sa kalsada walang use.
    yun L300FB is the best kapag namimili at nag-dedeliver. sa SM Home center nga pag may binibili ako furniture, binibigay ko lang susi sa mga taga-SM saka Plate number kung minsan. bahala na sila mag-load. I dont even have to worry kung magasgas kasi designed naman dun yun. eh sa pickup conscious na conscious ako sa pintura lalo na sa mga pahinante walang paki.
    pero one time, trooper ang ginamit ko pang-karga ng urinal, 2 water closet at bath tub. Sister ko na nasa passenger seat, halos dumikit na mukha sa windshield. sa estimate ko, di kasya ang length ng bath tub sa bed ng fuego...
    katabi ko, F150. Napakamot ng ulo yong may-ari ng F150 na nag-unload ng mga basag na tiles.
    tama si oldblue... since then, L300 na ng bayaw ko ang hiniram ko panghakot.
    So pang porma lang talaga ang labas ng strada. hehehe...
    Sir Otep, anong bang AUV na di masyadong bouncy ang ride? Mga pajero local and converted, pareho ba ang ride? Bouncy ba ang both?
    The Pajero will not ride like a car. Pero it is less harsh than a Strada. Best pa din if you do a test drive. Some people find Pajeros 'matagtag' also. Sakin ok lang naman. Local at converted will depend on condition of actual unit. My '96 rides better than the abused '01 Pajero owned by the hospital.
    The Strada has its own purpose. If it fits your needs, ok naman siya.
    Mar 2005
    strada ride is not really that harsh. actually matigas talaga pang-ilalim nya and the shock system, (in comparison with the reviews about the Hilux/Fortuner bumpy ride here) is way better. the ride has never been bumpy sa'kin after 6 years city or highway driving.
    ngaun nga pagtapos ng bagyo, madalas ko dinadala ito kasi kayang-kaya nya mga potholes na nasira sa daan due to hard rains and floods last week. and I dont feel the bumpiness as compared to my dad's all-time FWD explorer.
    my only complaint with it, sobra sikip inside. masikip na nga, I had to endure a longer vehicle pa bec. of the useless cargo area. minsan hirap ako mag-park, at hirap ako mag-u-turn sa mga u-turn slots na 2 lanes per side lang.
    overall, very thankful din ako dahil Mitsu ito, I get too enjoy some benefits of Mitsu's ever popular Pajero with less investment and maintenance cost. and it's even more frugal than the Pajero in terms of fuel consumption.
    dami nagsasabi dito pinaka-okey daw ang Isuzu pag dating sa diesel vehicles. I disagree. Mitsu talaga ang pinaka-okey pati riding comfort. The Pajero is proof of that na.
    The best pala talaga pag auto? I love to have a car but my family is growing so mahirap na maggastos ng dalawang vehicle, kaya I opted for the revo. I LOVE THE INTERIOR OF MITS LANCER, yun bago, classy talaga ang dating.
    Strada naman, I usually carries small dogs to vet, goes to picnic every once a month, kaya I was thinking of the acquiring STRADA. BUt I also have a Driver and a TRUCK to do that for me, kaya di talaga a "NECESSITY".
    cars nowadays kasi have multi-link independent suspensions, so softer ride, compared to like the pajero (2nd and 1st gen anyway) na solid axle suspensions.
    the lower center of gravity helps as well for cars.
    only lately lang na suvs are also having independent suspensions, like the new expedition, 3rd gen pajero, and so on.
    so that's why the best pa rin ang cars if you're just after ride comfort.
    Sa fuel, mas matipid ba ang revo 2.4 diesel kaysa strada 2.5?
    Mar 2005
    Quote Originally Posted by Dudee
    if you already have a driver, dont get the strada! trust me. the backseats are 90 degree seating most of the time. the passenger side is not exactly comfortable either. crammed leg room.
    mas ok ang strada for bachelors or 1-2 passengers lang. mahihirapan mga anak mo. I suggest you get a van na lang instead.
03 Hilux vs 03 Strada vs 03 Ranger 4x4
