Page 38 of 63 FirstFirst ... 2834353637383940414248 ... LastLast
Results 371 to 380 of 626
    Nov 2007
    #371
    2007 Ford Ranger Trekker
    All original pa , dipa na overhaul ang Engine
    223,500 km na tinakbo nya....
    Mar 2007
    #372
    Ano ba signs need na overhaul ng engine?
    Sent from my SM-A605G using Tapatalk
    #373
    Quote Originally Posted by suysuy View Post
    among others,
    black tailpipe smoke, oil pumping (malakas mag konsumo ng engine oil), loose compression (needs special equipment to determine), flickering oil pressure light...
    that no tune-up can alleviate.
    Mar 2007
    #374
    How about engine blowby?
    #375
    the first line is all about blowby, po.
    as a result of engine wear and tear, there's too much space between the cylinder wall and the piston, resulting in burnt gases leaking thru (blowby), resulting in poor engine performance.
    also, oil manages to get into the combustion chamber and gets burned along with the fuel. this results in excessive oil consumption and black tailpipe smoke.
    #376
    Odometer reading as of today..... 197265 miles (317467 km).
    #377
    I checked this morning and the odometer is at 199,854 miles (321,634 km). I never had a car last this far before. The closest one was my turbo Diamond Star coupe. It reached 167k miles. But, it's engine was also dead.
    The Sonata is doing very well, considering I'm much more abusive to it than the older coupe.
    #378
    Yaay! My car is at 200,091 miles (322015 km). 2006 Hyundai Sonata 3.3L V6
    i might overtake you mid 2019 🙃
    #380
    i might overtake you mid 2019 ��
    Only if I stop driving the thing. I intend to drive it until it falls apart. ;)
high mileage cars - what's the clock of ur odometer?
