Originally Posted by
pingpongdad
vs the montero,
1. in driving comfort, its hard to beat the innova, i find myself fidgeting in the montero trying to get that sweet spot especially in long drives.
2. the 2nd and 3rd row seats also are more comfortable and wider in the innova.
3. maintenace will be cheaper with the innova.
4. city driving, stop and go traffic, the innova is much more suited. not much use for the power of the montero's engine.
5. toyota's alarm system, allows you to lock the doors without the need to start the engine. in the montero's default system, after disarming the alarm and entering, you cannot lock the doors without turning the ignition on first.
6. if you get the innova, better the g, it has arm rests for the 2nd row for comfort which can be folded for another passenger seat. the v has captain seats in the 2nd row which seats only 2.
7. driving a monterosport makes you a little more "choosy" regarding parking (security-wise) vs an innova.
if you have other uses than the above, need for power, higher ground clearance and flood fording ability, strong road presence, etc, the monterosport is the one for you. do test drive both, that will be the clincher so you'll be able to make a more intelligent choice. hope this helps.
