Results 31 to 40 of 40
- Jul 2011
- 399
May 20th, 2012 12:38 PM #31It really depends on the usage. In our case we choose innova over the monty are the following:
1. Medyo old na parents ko, entry and exit convenience in at the utmost importance. Included also that my daugther will start to learn to walk na rin, just for safety precaution, a lower entry/exit point would be a plus factor for kids na makukulit
2. Monty has proven its worth and we have 2 monty na sa family so we decided to try something different naman.
Yun lang till now hindi pa lumalabas yun innova namin. Sayang hindi na naabotan ni papa, he passed away last week.
Ok sana kasi both parents of mine tried the display unit and they both like it especially the entry and exit from the second row. Dad was having a hard time climbing in and out of the monty kasi
May 20th, 2012 12:40 PM #32
so basically, sa comparison na to one of the main difference na pwedeng basehan ni TS is the maintenance cost ang FC....
mas mataas maintenance cost and FC ng Montero compared sa Innova...
- Mar 2012
- 118
May 20th, 2012 06:41 PM #34vs the montero,
1. in driving comfort, its hard to beat the innova, i find myself fidgeting in the montero trying to get that sweet spot especially in long drives.
2. the 2nd and 3rd row seats also are more comfortable and wider in the innova.
3. maintenace will be cheaper with the innova.
4. city driving, stop and go traffic, the innova is much more suited. not much use for the power of the montero's engine.
5. toyota's alarm system, allows you to lock the doors without the need to start the engine. in the montero's default system, after disarming the alarm and entering, you cannot lock the doors without turning the ignition on first.
6. if you get the innova, better the g, it has arm rests for the 2nd row for comfort which can be folded for another passenger seat. the v has captain seats in the 2nd row which seats only 2.
7. driving a monterosport makes you a little more "choosy" regarding parking (security-wise) vs an innova.
if you have other uses than the above, need for power, higher ground clearance and flood fording ability, strong road presence, etc, the monterosport is the one for you. do test drive both, that will be the clincher so you'll be able to make a more intelligent choice. hope this helps.
- Apr 2008
- 6,237
May 21st, 2012 12:09 AM #36Being a bestseller, takaw carnap din ang Innova eh. Pare-pareho lang sila. As compared to the Fortuner, the Innova is actually quite agile due to the lesser weight. With the torque coming in early and such a wide torque plateau, its really not very far off from the non-VGT Montero in terms of performance and with a significant advantage in the fuel efficiency department. The Innova's flood fording ability is also quite respectable. Don't let the minivan shape fool you, hood level floods are no problem for this one!
But then the Innova is not really very comfortable. Though better than the Fortuner, it can still get quite harsh at times due to the ladder frame chassis.
BANNED BANNED BANNED
- Feb 2011
- 1,442
May 21st, 2012 12:38 AM #37
- Mar 2012
- 118
May 21st, 2012 08:56 AM #39"But then the Innova is not really very comfortable. Though better than the Fortuner, it can still get quite harsh at times due to the ladder frame chassis."
innova seats have better thigh support vs the montero. and i think for bigger and taller drivers and longer drives more comfort.
the montero is also on a ladder-frame chassis.
several fora have compared comfort between the fort and monty. its always the monty which has been regarded as the one with better tuned suspensions. the 2012 fort has been said to have adjusted its seats (i guess, more padding) and tuned its shocks and suspension for a much better ride but then again, the comparo is between the monty and the innova.
still the best way for the TS to know is through a test drive. it will give real time feedback to the end-user, whose opinion is the one that matters anyway.
May 21st, 2012 09:22 AM #40
Car-to-car, the Monty does have more to offer (higher ground clearance, power, etc) and i'd never consider the Innova V even if i could afford it. For me, the best Innova model to get is really the E variant if you're just looking for a good and reliable, all around vehicle. Thus, if you're at that price range already, go for the Monty but if you want to save more, get the lower variant Innova.
I also agree with Niky on floods. Yes the Monty would be more flood fording capable but would you even really venture into high waters unless ultimately needed?
*AKI, condolences and my prayers for your family bro.Last edited by vinj; May 21st, 2012 at 09:26 AM.
