Results 1 to 10 of 19
- Jun 2012
- 18
May 27th, 2019 12:12 PM #1Been reading here, find myself confused what to buy, with a 300 - 330k budget I can avail a honda city 2009 or 2010
also can avail a vios 20011 or with luck 2013.
some say honda city are more efficient in terms of fc, others says go with the newer model vios 2012 higher.
putting maintenance in the equation, which will be a better choice? thanks
- Aug 2017
- 321
May 28th, 2019 12:37 PM #2So far, what you've read is correct.
I am a Grab Operator (16cars), 25yrs in transportation business, I've had almost all models of Vios and personally owned a 2009 City.
FC: Vios' FC is horrible, 2nd worst in my book (worst is Ford Fiesta). City is in the middle in terms of FC.
Maintenance cost/Durability/Reliability: Vios beats City. But, it does not mean that maintaining a Vios is the cheapest. Rack n pinion of Vios will take you 30k+, stab link 1800 (orig) / 850 replacement, radiator fan assembly P5, 600...These are the common problems of Vios Gen 3. Vios a/c is not as good as City's. I replaced the wheel bearing hub of my City... P35 (orig)
My wife's car is a 2013 Altis... Safer, bigger, worse FC vs Vios (smaller engine) ...
Buy a car based on what you value most, based on what is important to you. You can't have it all you know.
- Dec 2011
- 22
May 28th, 2019 03:26 PM #3Very well said 'SidCoronel'
"Buy a car based on what you value most, based on what is important to you. You can't have it all you know"
- Jun 2012
- 18
May 28th, 2019 04:39 PM #4
- Aug 2017
- 321
May 28th, 2019 04:48 PM #5
BANNED BANNED BANNED
- May 2019
- 6
- May 2019
- 312
May 30th, 2019 06:56 AM #8Are gonna drive it everyday? If not, fc between the two should be irrelevant. If yes, how far? If it's a short drive, fc between the two shouldn't be a big factor.
The're be both reliable vehicles and parts should be closely comparable in costs. Get the one that you like more to drive (handling and ergonomics wise), and consider outside aesthetics as well.
- May 2019
- 8
May 31st, 2019 08:51 AM #9Hi! Any recommendation po between these two? kasi dalawa lang po ang choice ko so far, 1st is a 2009-2012 model Honda City and 2014 up na Mirage G4. Our current budget is 300k-350k. It will not be used as an everyday vehicle po, siguro 2 or 3 times a week lang and most of the time 2 or 3 na sakay lang po including me, occasional long trips with 5 persons. Thank you so much for your feedback
- Aug 2017
- 321
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
