Results 1 to 7 of 7
May 11th, 2009 11:09 AM #1
The Lancer was design and built in 2006, but models are still being made until now (2009).
The Vios, has a new platform? And was it designed in 2007/2008?
Both prices are not that bad for budget conscious buyers.
I believed the prices are:
Lancer GLX is at P638,000
Vios E is at P659,000
Mas ok ung cost nung Lancer and both are all powered, although Vios has a fresh and newer design.
Checking the specs.. Both have driver-side airbags, wala lang ABS ung lancer glx. Although, the brakes are discs na (front and rear), while ung vios E front lang and drum pa din sa likod.
In terms of power, mas malakas ung Lancer GLX (1.6 SOHC) based on the specs at 110HP/6200 rpm? While the Vios E (1.3 DOHC) is at 85HP/6000 rpm? Correct po ba?
In terms of maintenance, do you think mas madami nang nakaka alam na mechanic about the 4G18? Since it is around for quite sometime? I've read 2002 pa ata eto built?
Help naman guys, what do you think is the wiser choice?
Currently, I am leaning over the Lancer GLX. But, if may na miss pa akong point na dapat malaman, please do tell po. Salamat!
May 11th, 2009 11:14 AM #2
the wiser choice is the lancer. its bigger and have more amenities. mas malakas ang lancer dahil 1.6 ang engine nya, compared to the 1.3 ng vios. but of course, higher engine displacements equates to higher fuel consumption.
May 11th, 2009 11:35 AM #3
If resale value is a concern, then Vios is the way to go. The most bang for the buck in terms of feature and per pound of metal, its definitely the Lancer
May 11th, 2009 11:41 AM #4
Don't see much of the 2006 model Lancer on the road. Anyone here care to share their ownership experience?
May 11th, 2009 12:25 PM #5
Im one of the owner of 1st batch of lancer 2005 with 4g18 engine.. mine is GLS with CVT tranny.. with 60k++ on my odometer still no problem... regarding maintainance wala nman problema...its brandnew so 3 years warranty... if i were you add some cash and get the GLS you will enjoy the convinience of automatic at the same time the sports mode of CVT...
May 13th, 2009 05:25 PM #7
Hmmm. with that money, pwede ka bumili ng Hyundai Accent CRDI VGT.
It's superfast (can do 200kmh+ easy) and super-economical (30+kms/L on long drives) at the same time since it's diesel (Bosch common-rail diesel with BorgWarner Variable Geometry Turbocharger).
That is, if you don't have anything against Koreans and Hi-tech diesel. Test drive to believe. :D
Xiaomi E-Car
