Results 1 to 15 of 15
    just curious....
    Who among all units have the highest (ORIGINAL) ground clearance?
    What units?
    Ground clearance is measured from the ground to the lowest point of the vehicle (under the differential on trucks and suv's, usually the bumper or sills on regular cars (mudflaps not included)
    Jun 2010
    Quote Originally Posted by Dudee View Post
    just curious....
    mostly 4x4 pick-ups.
    Sa pickups I think its the Ford Ranger (ground to diff) pero mas mataas pa din ata side sill ng Hilux that's why it looks taller.
    sa mga kotse po?
    just curious....
    sedans, vans, suvs, or pickup trucks?
    standard factory? the land rover defender probably. heh heh.
    sedans?
    any any sedans run/ out stand a knee level flood?
    sedans?
    can any sedans run/ out stand a knee level flood?
    sedans?
    No. At that level of flooding, either water has started to enter the car's interior or the cat body would have started to float in the water. Either way, knee high flood waters will have consequences on the car's mechanicals and electronics later.
    What do you mean by withstand?
    Most cars breathe air from headlamp level and the engine will survive the ocassional dip. I've forded water to the headlamps in my old Benz with no problems.
    As to water entering the cabin, that's another thing. Water may seep into the cabin but most of the time you will make it across the water crossing.
    If you want to make it through unscathed, a sedan isn't the right tool for the job. Better get a Suzuki Jimny or something.
    Get the old land cruisers. ;)
  13. #13
    get a jimny...of an auv like avanza J.
    kotse are not built for water forging, unless ung tinest sa Australia na water car.
    Feb 2009
    for inquiry's sake, it will be the german unimog followed by the original military hummer ( not the wanna be hummers)
    Aug 2010
    Bummer if I see an original military Hummer in EDSA sobrang lapad nun...
ground clearance
