Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
    #21
    Quote Originally Posted by eydan_yuan View Post
    Thanks for all your replies...
    btw, if you don't mind, which variant did you finally end up with? i'm in the same quandry as you were now.
    Jun 2007
    #22
    i've read recently about an aftermarket gadget called Sprintbooster for fortuners.this could be a good help in case you choose the 2.5 D4D in giving extra boost in power,though it was'nt indicated if applicable for vvti also.for those who were among the first to buy,did the suspension soften somehow given that your units are more or less 3 yrs. old already? inputs please.
    in addition, toyota should have made suspension improvements this time for these fortuners for sure are here to stay
    it will be helpful also if somebody can comment regarding the FC of both engines.thanx
    Jun 2007
    #23
    yes, sprint booster is applicable for both d4d and vvti engines.
    Aug 2004
    #24
    It doesn't give extra power.
    What the Sprint Booster does is alter the signal going to the ECU from the pedal in cars with electronic throttles, so when you press the pedal slightly, it modifies the signal so that the ECU opens the throttle sooner and at a bigger angle than you request.
    It combats throttle-lag (a real problem on some ECT cars), but it doesn't make the car any faster against the clock.
Fortuner 2.5D4D & 2.7VVTi: Pros and Cons
