Results 11 to 20 of 26
June 8th, 2006 10:12 PM #11
well, the newer engines are still the best..crdi's....
pero, since ung suki nating mekaniko di alam yan kalikutin, dun ka muna sa mechanical old reliable engines, 4d56, td42, 2c, 3c, td27, 2L, rb's, etc...
June 15th, 2006 08:44 PM #13Originally Posted by oliver1013
payong kaibigan lang pre, pa adjust mo un valve clearance ng crosswind mo. if you said na since bnew bili mo e hangang ngayon parehas paren... it means nasanay kana sa ingay. pero im sure after running 80T kms, malaki na clearance nyan. Magugulat ka after mo pa adjust un valves e mas tatahimik yang crosswind mo. Mura naman lang ang labor e.
- Dec 2005
- 57
June 16th, 2006 02:23 AM #15any comment on the Matrix Crdi engine? what is the fuel consumption? Is it true that diesel engines are more expensive to maintain than gas fed engines in the long term?
- Aug 2004
- 108
June 16th, 2006 08:53 AM #16The engine of the D-MAX (4J-H1) seems to be a good engine. Although I don't own one, friends who own one don't have any complaints with it. Its a bit noisy than the other Diesels but once inside the cabin its quite comfortable.
Diesel engines have really gone a long way since the mid to late 90's. Today we have diesel engines that have the horsepower comparable to compact sedans (stronger even than others) and almost or better fuel mileage. Maybe someday japanese diesel engines will be as good as the german diesel engines.
June 16th, 2006 11:53 AM #18
pajero's 4d56 & 4m40 under powered, but very strong for a Space Gear Delica.
nissan teraano's td27 under powered
trooper's 4jg2 maingay lalo na sa Manual
Toyota Turbo Diesels new and old models = all I can say is that the Turbo whistle really sounds good. sa sound lang... hindi ibig sabihin sa performance...
June 16th, 2006 12:14 PM #19
Has anyone tried the hyundai crdi engine on the accent sedan?
Mukhang this is a new generation crdi like the one in the tucson. Fuel economy and torque are best in class daw...ewan ko lang sa maintenance kung may issue. Or sa fuel filtration like in the d4-d of toyotas.
- Aug 2003
- 9,720
June 16th, 2006 12:38 PM #20hasn't the CRDi starex been around for about 2 years now? parang wala naman akong naririnig na problema
agree... but I don't think its the "T" Badge. kasi the Livina at 1.2M is basically the old...
All New Toyota Corolla Cross
