Results 1 to 10 of 1594
Threaded View
    i'm not sure what you're asking for, but you can lock it for "2" and for "3", or go full 4.
    "D" will let the car go from 1st gear to 4th gear.
    "3" will let the car go from 1st gear to 3rd gear (ie. D3 on Hondas). Can be used on extended uphill drives to prevent gear hunting
    "2" likely means it is locked on 2nd gear. It's typically used in cold climates to help prevent wheel-spin on snow
    3 and 2 can also be used if you need engine braking on long downhill drives
    ah so "2" is the lowest gear in the wigo for driving on steep roads .
    all our a/t vehicles are tiptronic now so they don't have the "2" or "3" gear options. and like i said, i haven't driven nor ridden shotgun in a wigo yet so i don't really know its gear lay outs.
    i remember our old gd jazz had an "L" gear even though it was already equipped w/ a "manumatic" feature.
    thanks for clarifying bros!
Battle of the Transmissions: M/T vs. A/T
