Page 1 of 2 12 LastLast
Results 1 to 20 of 1594
    Jan 2008
    ^^ +1
    Ang ayoko lang sa AT/CVT during long drive bka anytime bumigay alternator or battery, siguradong abala to.. MT excels during this scenario esp emergencies..
    Dec 2007
    Alternator, bibigay? Small probability.
    Battery, bibigay? Kung pabaya ka...
    (ring)...
    MOTOLITE DELIVERY... how may I help you?
    Sana nationwide na 'to. haha.
    Quote Originally Posted by woohoo View Post
    (ring)...
    tama ka jan woohoo.
    pero may hidden charges pala yang delivery na yan :bwahaha:
    Jul 2006
    well pag utilitarian vehicle which hauls heavy objects, M/T talaga, Manuel you control your ride, automatic the transmission chooses for you, I like and I choose/prefer manual because both of your leg/feet are working.
    I don't like A/T because according to my observation, nowadays many automatic cars, the driver is doing another thing while driving, like for example, texting, calling, using their cellular phones, which they are not to be done.
    Aug 2004
    That part ain't exactly the fault of the transmission.
    I have a cousin who used to be able to put on his uniform (including pants) and eat his breakfast while driving a manual transmission car...
    kaya dami nai-stroke e, konting pagod ng isang paa ayaw na agad. pansinin nyo pag na stroke karamihan patay kalahati ng katawan gandang exercise yan for free even pag may naka away ka malakas kang sisipa on both legs joke
    what can you say on those who do not want to be bothered by the manual tranny cons then go the gym to have their work outs???
    if you have the budget on the extra cost re maintenance then there's no debate about this. a matter of preference prevails.
    peace
  7. #7
    Quote Originally Posted by grid View Post
    well i have seen elfs and canters in the auctions(from japan) that are matic..
    and look at the japanese sites of isuzu and mitsubishi. canters, elfs... even hino have automatic tranny.
    well its not the ATs fault.. blame the driver!
    i used to drive m/ts. i had misconceptions then about a/ts being slow, gas guzzler and not so powerful.
    then i purchased a sorento a/t and my eyes were opened to the convenience, comfort and driving pleasure using a/ts. the sorento is such a pleasure to drive that i sometimes i dont use my driver anymore even for long trips. now, i will never go back to m/ts.
    in fact i recently purchased a strada (gen 2 lang, walang pambili bago) and i opted for a/t. mind you, i do mainly drive my vehicles in the province but still i prefer a/ts.
    why? because im just a regular driver, not the racing type, not even the offroader type.
    as for the fuel consumption, i suspect i even made better fuel consumption with a/t because i usually lift off my foot when driving to take advantage of the free wheeling mode of a/ts when coasting.
    just my 02 cents and change
  9. #9
    Quote Originally Posted by jatcos View Post
    ^^ +1
    well kung nasiraan ka ng alternator or battery kasalanan mo yan! and its not the AT's fault...
    but if nasiraan talaga...the main difference between AT and MT when towing:
    MT - just neutral then GO.
    AT - tow for only a maximum of 30 mins/10kms..if long towing is required, REMOVE THE DRIVE SHAFTS so that you'll not overheat your AT and cause severe damage to your AT/cvt
    Jan 2008
    Yup, poor maintainance is the owner's fault but M/T still excels during these kind of emergencies..I remember when we were about to board a ferry going to samar and our battery died, good thing my brod brought a spare battery in anticipation for the trouble.
    Production and ownership doesnt have that much gap between m/t and a/t nowadays since technology of A/T already improved. A/T using big oil coolers can haul heavy load, provincial buses with Man badge uses ZF automatics.
    Quote Originally Posted by alwayz_yummy View Post
    Di ba may neutral mode din naman ang A/T? Nang ayaw mag start ang honda ESI, pina tow ko siya in neutral mode at okay naman siya. That was year 2000 pa kaya lang 2 years ago nag overheat siya bayaw ko nag drive at wala ako, nakalimutan ilagay sa neutral kaya nagkaroon ng trans slip pagkatapos buti lang may surplus ako nakuha for just 8K sa banawe.
    Dec 2007
    What is "HARD TOWING" ba? Meron bang "SOFT TOWING?"
    Here are some insights on A/T and Hard Towing: http://rav4world.com/forums/viewtopi...c5432c74173b52
  13. #13
    Quote Originally Posted by jeanpierre View Post
    if you put AT to N, it will require the fluid to cool it. yan ang pagkakaiba ng AT sa MT.. susunugin mo yung clutch ng N-gear.. remember AT have multiple clutches than MT. each gear has its own clutch that are way thin that you see in the MT.
    thats why it should be towed with the drive shafts removed. you can tow if you LIFT the drive wheels. kung full-time 4wd, dapat nasa flat-bed.
    some part-time 4wd have a transfer case disconnect mode (aka neutral mode).. like Dmax.
    hard towing - towing * maximum loading at long periods of time.
    hi sa mga naka AT, ano diskarte nyo sa baha? ngayun lang kasi kami nagka AT, hehe di ko alam kung pano to pagdating sa tubig.
  15. #15
    just put it into 1 or lowest gear only, then drive with slight pressure on the brake pedals.
    this is to minimize the wave you cause when forging the water.
    for AT 4wds with Low position - switch to 4L then just set to 1.
    Oct 2007
    Quote Originally Posted by zuperk View Post
    Avoid it. Go around it if you can.
    Karamihan na din ng lumalabas ngayon matic na kaya minsan no choice...
    Ilagay mo sa L then apply a little pressure sa brake.
    pag bigla ka naman hiuminto sa gitna ng baha, ilagay mo kaagad sa neutral then rev the engine pero its a myth.
    hindi naman papasok ang tubig sa exhaust as long as umaandar ang engine.
    check your brakes lang pagka ahon sa baha,
    my observation kaya mostly matic ang available, dahil sa haba ng warranty nowadays, minimum na ang 3 yrs or 100K kms at yung iba 5 yrs pa. pag matic no way ma puwersa mo each gear and the whole engine therefore lesser ang potential damage sa engine. 3-5 years time? i don't think bibigay ang matic kung di aabusuhin
    hilig pa naman ng pinoy sa modifications. do you think kung may SIR pa na manual ilalaban nila ng 3yrs warranty or 100K kms.?
    isa pa mas mahal maintenance ng matic kahit saan tingnan, therefore again mas malaki kikitain ng casa another is very prone sa damage like baha, wrong gear selection at certain speed etc. esp kung ang ilang new owner ay walang hilig mag-ingat at gamit lang ng gamit. IMO
    Thanks bro! Good info
Battle of the Transmissions: M/T vs. A/T
