Page 1 of 4 1234 LastLast
Results 1 to 20 of 74
    Jun 2006
    Looking for a fuel efficent car for the wife. Will be used to bring kids to school, grocery, church etc.. Almost sure na pure city driving. She has a driver so I'm getting a base model manual tranny.
    I know that we are only speculating on the Avanza but since its a 1.3 vvti, can I assume consumption will be similar or at least close to the vios? I know it is heavier and if fully loaded will seat 7 people. We are a family of 4 plus yaya and driver. I do have a 10 seater van pero gas guzzler so i'd rather not use it. Its used for highway and when we are all together. Vios is lighter and will seat 5. I'm guessing price will be similar. I'm pretty sure vios will have more promos.
    I'm a bit concerned that Avanza might be under powered. Its supposed to be 89 hp and around 1085 kgs. Ok ba power to weight ratio nito? vios is supposed to have 85hp and curb weight of 930kg. So Vios has better power to weight ratio. Problem is I do not know what is the acceptable power to weight ratio. I can do the math but the numbers have no meaning.
    So which one is better suited for my needs.
    Mar 2005
    Avanza has very short gearing, supposedly 4000RPM at 100kph, this is to compensate for underpowered engine. A typical sedan will only do 3000RPM or less at 100kph.
    The aircon will have a larger cabin to cool.
    FC definitely higher than Vios.
    As for power-to-weight the Honda City 1.3S curb weight 1081kg so it weighs almost the same as the Avanza.
    Jun 2006
    what does short gearing mean? does it mean that you have to shift at higher rpms? Meaning instead of shifting at around 200rpm you need to shift at 2500 to 3000 rpm, para di sakal yung transmisiion, ganoon ba? if so then it should result in higher FC, right?
    Jun 2005
    Based on your assumptions, I'd go for Vios.
    Mar 2005
    Quote Originally Posted by userfriendly View Post
    Short gearing means for the same gear and speed the engine RPM is higher. You don't necessarily have to shift at higher RPM... but you may have to if fully loaded with 7 passengers...
    The short gearing means that when travelling at highway speeds, say ~100kph, the engine RPM will have to be higher, thus consumes more gas. But since you'll be using it for city only it's probably just fine...
    BTW judging from the pictures the Avanza interiors seem to be really cheap-looking, much worse than the Vios' which is already below-average...
    Jun 2006
    ^^Thanks for the explanation.
    As for looks, its not really important. Function, reliability, fuel consumption, maintenace cost are more important to me.
    Even at 89bhp, the Avanza still makes more power than 12 passenger vans like the L300, Kia Pregio, Toyota Hiace (older model), etc. And those vehicles have no problem hauling a full load.
    Corolla 1.3's with their heavier bodies also make around 90bhp. Same with base model Sentras.
    I don't think power will be an issue unless you're a power junkie.
    Jun 2006
    Thanks OTEP. I was worried that performance might be similar to the old Lite Ace. Come to think of it all the vans you mentioned have less power and can carry more weight than the Avanza and those models do an acceptable job. The L300 is even used as light duty delivery truck and its been around for ages. I guess this is a non-issue.
    Oct 2004
    but all of you are forgetting that those cars that you mentioned are all diesel engines .... it has more torque and can carry more weight ... sa alam our 2.0 gas engined hiace has more hp than that avanza .. but if your just sitting 7 people i guess 89 hp is enough ... yung suzuki nga kaya rin e
    Jun 2006
    Ano nga ba difference ng torque at hp, forgot kasi.
    Ang max load will most likely be 4 adults and 2 kids. I think 5 seater is enough pero kung madagdagan yung anak namin eh masikip na.
    naisip ko yung APV pero sabi ng pinsan ko 7km/l lang ang consumption niya sa city driving.
    torque vs hp?
    isipin mo nalang na ang torque ay kalabaw, at ang hp ay kabayo.
    mabagal ang kalabaw pero napakalakas nito sa hilahan kahit na mabigat ang hinihila.
    ang kabayo naman, mabilis, pero hindi kasing tibay ng kalabaw sa bigat.
    Jul 2005
    Foldable ba yung third row seat ng Avianza, if not di ba medyo masikip na ang space for groceries sa likod?
    Yup, that's why I mentioned the two compact sedans (with gas engines) in the mix.
    Btw, a Suzuki Vitara 1.6 4wd wagon makes 95bhp and carries more weight than the Avanza, too. The Nissan Vanette was also rated at 90bhp.
    Feb 2003
    even if the avanza may have shorter gearing, they might have made it's overdrive lower to compensate for highway speeds. just like suzuki super carry (ies?), w/ 44 hp it has a payload of 700kg + it's 730kg kerb weight, very low ang 1st and 2nd gear but relatively high and 3rd to 5th. anyway, you can see the avanza on september 22 to 28 at the 2nd toyota motor show sa le pavillion. and if you're not in a rush, wait till some members here buy one and ask their report on it's performance and consumption.
    Jun 2006
    Have to make a decision this weekend. Kakahiya na sa parents ko and in-laws, 3 weeks na kong nanghihiram ng auto. Take advantage na ko sa 2nd world of toyota promo ng 20k trade in certificate at kung ano pang manegotiate.
    BTW, when you said "you can see" does it mean na unveiling only and not for sale?
    Apparently, the first batch has been pre-sold.
    Why not the Suzuki APV? There's a bare version under 600k. Consumption under full-load is supposedly just so-so, though.
    Jun 2006
    Pre-sold na? Where did you get the info? I bet mga taxi companies ang umubos.
    I know APV mga 7km/l city driving. I want something more frugal.
    I think AG4 or someone else mentioned it in another thread, and, yup, mga taxi companies nga...
    Diesel nga lang talaga ang medyo good choice for fuel efficient seven seaters... but the next cheapest decent seven seater in diesel trim is around 800k or so (Innova) or 700k or so (Adventure/ Crosswind). To recoup their difference over the gasoline Suzuki, you'd have to do about 50,000 - 100,000 kms of city driving (at 9 km/l city vs 7 km/l for the Suzuki in heavy traffic... the diesels only do 10 km/l-12 km/l in light traffic conditions) to make up the price difference. That's about five years or more of driving to recoup the diesel investment...
    Of course, if you install an LPG system on the Suzuki, the difference will be negligible... at about 22 centavos per kilometer, or, if LPG consumption is around 6.5 km/l or higher, it will be cheaper than diesel...
    Jun 2006
    Hope na hindi pa sold out. Pero kung wala na eh di Vios na ko. Masgusto ko sana yung 7 seater pero 5 will do.
    Nacompute ko na dati yung price difference ng diesel kaya wala sa choices ko. Tagal bago mabawi. Tsaka, yung Innova D4D D4D = destined 4 destruction
    Yung original plan ko ay convert yung cefiro ko to lpg. Pero namatay na yung bwisit. Sobrang mahal nung piyesa. Di sulit ipagawa. Yung part ay pang down ko na sa bagong kotse. Kaya eto, looking for a new car.
    Have the same problem with the 626. I could justify the repair expenses if it were my only car, but... it isn't... thus, it's R.I.P. for now.
    Good luck, bro. Kung 5-seater din lang ang bagsak mo, ayaw mo ba ng Hyundai?
avanza vs vios
