Results 1 to 10 of 18
- Aug 2003
- 9,720
April 4th, 2013 05:24 PM #1Hi peeps,
Is it worth shelling out the extra 125k+ pesos to get the 1.5L variant, based on the engine specs:
1.3 E M/T 1.5 G 5-Speed M/T
Max Output 90HP / 6,000 rpm 102HP / 6,000 rpm
Max Torque 117Nm / 4,400 rpm 136Nm / 4,400 rpm
Price 703,000 828,000
The 1.5 G variant does have driver+passenger airbags though. tia
April 4th, 2013 05:38 PM #2
imho. the engine power difference is not worth it... unless you are planning to load it with heavy loads and kung parati kang aakyat ng bagyo.
the airbags though is worth it.
April 4th, 2013 05:54 PM #3
Hindi naman dramatic ang difference sa power pero kung sensitive ka, mararamdaman mo ang difference. Pero IMO mas matipid para sakin ang 1.5. Pro malaking difference na yung sa torque ha. Mas kailangan mo yun over the HP.
- Aug 2003
- 9,720
April 4th, 2013 07:18 PM #4
- Nov 2010
- 369
April 5th, 2013 09:37 PM #5
- Nov 2010
- 369
April 5th, 2013 09:43 PM #6Rims -20-30k with tires na yan depends on your choice.
Pioneer hu with usb cheapest would be around 2k-3k
Speakers - about 3-4k siguro
Alarm system around 1.5k
Horn - 1k-2k depends on your choice.
Fog lamps maybe 3k
Just dont put chromes. :D
- Jul 2009
- 3,604
April 5th, 2013 09:46 PM #7No substitute for safety. Airbags palang sulit na.
Kapag city driving lang, baka not so important though.
- Aug 2003
- 9,720
April 5th, 2013 11:08 PM #8A friend of mine mentioned that the entry level, "pang taxi" avanza's chassis has thinner steel, compared to the other variants. How true?
April 6th, 2013 01:04 AM #10
I bet your friend based his statement from the fact that the Avanza J has thinner door trimmings than the E/G variants. However, it's no way indicative of how thick the steel behind the car is. Also, I don't think it makes economic sense to have a different line to create a completely different chassis for the lower-end variants.
When was the last time you changed them? If it's been a while, I suggest following your mechanic's...
Rubber boot question (repair or replace)
