Results 1 to 10 of 11
- Jan 2012
- 54
February 19th, 2012 11:39 PM #1I just would like to ask what is the common problem on Mitsubishi GSR?
is it a good car for everyday driving from parañaque to katipunan ?
is it fuel efficient?
is it fuel injected or carburetor padin?
February 20th, 2012 09:34 PM #2
I had a GSR very briefly (8 months) in 2002. Only reason I sold it very quickly is that I had a chance to get a 2001 316i (for cheap) from a friend who left the country and needed to unload his car. The GSR is fuel injected. Fuel consumption is not as good as the new cars today with similar engine displacement and power. I get about 6-7.5 km/l then (if I remember correctly) in comparison my 2000 SiR back then consumes the same amount of fuel. Overall it is fun to drive, handling is average, looks (one of the best during it's time). Definitely not a family car though.
- Apr 2008
- 6,235
February 20th, 2012 09:55 PM #3Well, it is a pizza Lancer so I suppose the suspension woes known to plague this model is also present in the GSR. I'm not so sure though if the newer ones are affected. The GSR is basically just a Lancer with two doors less. There are no performance advantages over the sedan version expect for, perhaps, a bit less weight. Being a coupe, it is a driver's car. But it is no different from other 1.6L compacts of that generation in terms of fuel efficiency and performance. Though it definitely does look pretty good, especially the facelifted version. But then, it is impractical to get a car having no performance advantages over its sedan counterpart and has a huge chunk of interior space taken away and the inconvenience of having two less doors. I'd suggest you look elsewhere.
- Apr 2024
- 3
- Jun 2005
- 3,774
April 2nd, 2024 08:10 PM #6Notorious ito noong araw sa nasisira ang transmission ah....
Sent from my 2107113SG using Tsikot Forums mobile app
- Jan 2007
- 2,581
April 3rd, 2024 06:16 AM #7^ Hindi ba dahil prior to the 90s maybe 98% of our cars were all manuals and people didn't know that the A/Ts needed maintenance too and just used them forever without doing periodic maintenance like fluid and filter changes?
IIRC another A/T that was considered sirain back then was the Honda Accord, which if you look at the same model in the US the transmission wasn't considered problematic, and they drove way more miles than we did.
- Jun 2005
- 3,774
April 3rd, 2024 08:46 AM #8I remember that invecsII of mitsubishi. This had a lengthy discussion sa old tsikot boards as well as kotse(dot)com. Nasisira na lang basta kahit regular ATF change. Toyota and Honda has automatics that did not randomly break back then.
April 3rd, 2024 02:46 PM #10
the car was released around 1997 (5th Gen Mirage/Lancer)
if you plan to use it in 2024... its almost 30 years old! older that our panganays.
I personally know only 2 people who has a near-perfect condition same Gen Lancers - 1 is a daily driver, while the other is a garage queen (common joke namin na sa loob nun ginawa yung panganay nila)
Ah ok. So Wala pa Lang locally released na delicà dito. Pinapakyaw kasi Ng mga outdoor lovers...
Mitsubishi Philippines
