Tsikoteers,
How's the resale value of the Subaru Forester & ease of maintaining in comparison to other brands. Though many might say Toyota, how does it par with other brands? Thank you.....![]()
Tsikoteers,
This has been discussed over and over already. Just go to the subaru section and back read a couple of threads.
like i said it has been discussed over and over again by owners and non owners. even in car comparison section it has been discussed over and over and every time some one considers a subaru this exact question is always asked. on the subaru section you can see actual prices of pms and parts. here in the comparison section you won't really get enough details since most people assume it is expensive to maintain based on nothing or sabi ng nanay/tatay/lolo/lola/kuya/ate/kapit bahay/kaibigan/kabit/aso ng kapit bahay.
anyway here's a post by niky one of the most informative members here comparing the rav4 and forester.
To TS: cost at PMS for subaru 2.0 NA engine is the same as any Toyota 2.0 engine sa casa. +- 1000 php. If u buy a turbo subaru, it will be more expensive.
Thank you all, totally convinced na. I will be getting the satin white and there's one more satin white in Pampanga Subaru for anyone interested. My choices are red and white since the black accent design are more visible at head turner talaga when you see one. I plan to replace the stock mags & tires para mas gumanda ang tindig pero keep ko rin yung stock during pms para di ma void warranty. Also replace the HU with flyaudio pero ask ko muna dealer to make sure di ma-void warranty. Will post more sa forum to help others as all of you did....
Comments naman yung max offset rims na pwede....
don't worry about your warranty as long as you put the right size and off set then there is no reason for MI to deny your warranty, also even the flyaudio there is no way MI will deny your warranty because of it since it is plug and play. that's the best thing about MI, when it comes to after market parts they aren't that strict. unlike other casas na palitan lang ang rims wala na agad warranty.![]()
Growl audio ata better. I replaced mine, outside of casa, may warranty pa rin naman yun car ko dati.
I have no idea why people are that obsessed with their warranty. I would be iffy if the warranty covers something important such as the powertrain -- engine or transmission.. but seriously, wheels? Just jack your car up and replace your aftermarket wheels with the OEM ones if you're so worried.
And no, there's no such thing as safest or best all around. But it's highly discouraged to splice your wires up. Even if it's plug-and-play, installing an aftermarket radio should and would still void your warranty.. and example would be: assuming your tweeter doesn't have a filter on it (capacitor, passive crossovers, etc.), it's easy to make a plug-and-play radio that would throw 20hz at a tweeter and blow it.
But between Growl Audio and FlyAudio, I'll still pick FlyAudio. No, the specifications isn't better but rather because I know the importer and distributor personallyPersonally, I'll still get a Pioneer or Alpine head unit.. but I'm simply the minority.
