Page 1 of 2 12 LastLast
Results 1 to 20 of 62
    mga sir help naman my cousin is buying his first car he's been torn between the two? pa advice naman in terms of overall performance and the value for money... as for me i would stick for isuzu crosswind for i have a 2003 crosswind and no problem at all for almost 9years (no personal experience with advie)... thanks in advance...
    If he wants it to circle the globe plenty of times with minimal maintenance..Isuzu.
    Oct 2011
    go for the XUV.
    Apr 2008
    Between the two, Crosswind nalang. Mas matipid, mas malakas sa akyatan, at mas malawak sa loob. Pero kung sa ganoong budget, Innova parin.
    ^^between the 2 XUV but Innova diesel is way better as GTi mentioned.
    Oct 2011
    oh yes, i hope TS would consider an Innova.
    Nov 2011
    we have isuzu
    failure talaga..
    go for innova!!
    Nov 2011
    we have isuzu
    sportivo xmax walang kwenta
    lalo na advie
    go for innova!!
    Feb 2011
    Re: 2011 croswind XUV or 2011 adventure GLS SPORT
    adventure super tipid at tahimik yung engine, matibay yung engine at pang ilalim, all stock!!! exept for the brake pad and tires....as of now my km reading is 390+++.. and still counting,.. Mega taxi sya ...thats my experience..TS, the ball is all yours..
    Oct 2011
    *dhon,
    it will also help if you would tell us where are you going to drive your new vehicle e.g. highway? city? off road? province?
    WBR,
    Isuzu ako.
    thanks mga sir sa reply...
    well as for the use dito sa pampanga mag be-base yan and seldom trip to bulacan kasi taga dun yung asawa ng pinsan ko... medyo maayos naman ang mga roads dito sa pampanga and bulacan and also it will be use sometimes sa rough road (not that rough)about 1km papasok dun sa farm lot nila......
    kaya di kinonsider ang innova and most likely they will go for xuv kasi mas need nila ung high ground clearance with bigger tires and with still a space for some luggage or farm equipment...they did not consider pick-up's kasi need din nila atleast seven seater for their out of town family outings...
    sir ask naman ako where can i get the best deal sa mga isuzu dealer...
    as for financing anong bank ang may pinaka mababang interest rate they are planning to get it at 50% d/p and 3years term...
    TIA...
    Jan 2012
    pwde, mgccnungaling ka kung d ka nka 1-2 times palit ng timing belt mo?belt driven ang adventure db? isuzus can go up to 500-600-800k w/o having prob in its engine because its timing gear..bsta proper change oil/alignment ng tires lng tlg.. ms matipid din isuzu kesa sa mitsu..
    Jul 2011
    Nakakatakot lang sa hiace is the maintenace, once parts starting to fail na tuloy tuloy na. A front uPper suspension arm for each side cost almost 11k. Ouch! Even the old model hiace gsnon rin yun price ng suspension parts niya. For me maganda siya and its equipped with a better engine compared to tye urvan but in the long run masmakakatipid if you end up with an urvan. I interviewed some delivery using urvan. According to them at an average this van is only consuming 14km/liter. Down side is mabilis daw maubos yun front tires. Kaya parwng gusto ko palitan yun isang old adventure namin into a urvan soon or as soon i can save atleast 50 percent for downpayment then remaining balance for 3 years.
    Quote Originally Posted by AKI125 View Post
    Baka yan na nga yung sinasabi ng kausap ko, nagulat nga ako e, dahil ako alam ko crosswind so far parang pag nagkaroon ng nuclear war ipis lang at isuzu ang mag survive pero yun nga Urvan din daw..
    Jul 2011
    AFAIK another big problem of the Crosswinds are the door hinges, mabilis masira. Can someone clarify this?
    Jan 2011
    Had no issues about the Hinges with our 5yr old sportivo
    and napaka minor naman yan, not an issue in-case masira
    Jul 2011
    Quote Originally Posted by andretti View Post
    Actually it is, saw one before having a hard time closing his drivers side door sa mall parking. Pinipilit niya saraduhin yun door, the way it looks na disalign due to the upper door hinge gave way. After 3 hours of malling, andoon pa rin yun guy still thinking of a way to close the door properly.
    Apr 2008
    Haha! Ang tindi naman niyan! Yung Revo namin nakakatumataginting na sampung taon na wala pang problema sa kaha!
    *samcoy: Ang Crosswind walang airbag. Kahit sa driver's side wala. The steering wheel is quite padded though. Very bad considering the price tag. And then pwede naman lagyan ng airbag ang Crosswind eh. That dashboard has a big hole in the passenger side diba? Pang airbag dapat yan! I've seen Wizard's with the same dashboard and with airbags.
    Jan 2011
    Do you mean all crosswinds are defective and are having this hinge issue? have you seen a dozen to conclude this? I doubt it bro... Pero I totally agree with you guys, overpriced talaga ang mga Crosswind and Sportivo models and are lacking in safety features. Ang laban lang talaga nila is tibay....
    Kaya * TS if your really worried about all this then the crosswind is not for you, then again who would want to have an accident anyway...even a better safety equipped car is not 100% safe.
    Just my 2 cents po...
