Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Apr 2009
    My ESi:
    *Same specs and issues, see:
    http://tsikot.com/forums/car-compari...ird-u12-88615/
    *B13 owner saw my post on the U12 ad and offered me for a straight swap deal with this:
    http://www.**************/index.php/...a+Super+Saloon
    My dream engine:
    http://cdn.sulitstatic.com/images/20...a02ec60556.jpg
    Good deal?
    How much add ko if ever?
    The owner is keen to let go of the car asap, and I'm not afraid there might be some issues.
    But what something major should I expect from an SR20VE in a B13?
    I remember GH and Niky told me about axle fitment issues of SR20DEs in B14s before.
    Is this a similar case?
    Need to decide soon.
    Thanks po.
    Aug 2004
    Axle issues will depend on the transmission source. If I recall right, the 20VE is a Primera motor, and that car is wider than the Sentra.
    How much is he asking?
    ganda pa nung B13 ah..... naka 17s ba yung mags?
    Jun 2007
    Check the wirings, check if the variable intake and exhuast are in proper working order. Its better to log in also to any sentra forum( preferably local ones) to look for an expert shop for them to check the installation both mechanical and electrical( as well as the electronics) are done properly.
    Apr 2009
    Straight swap sir, but I'm quite hesitant kasi madami talaga issues yung ESi ko dahil sa kaluman. Think 410,+++ km on the odo says all. Although I enumerated them to him, ang worry ko is baka after ng swap eh balikan niya ko bakit ganito, bakit ganun yung ESi ko.
    As per the ad (re axle and transmission):
    SR20ve NEO VVL engine
    SR18 Non LSD Manual Tranny
    P11 Axle
    16s Rota Track R yata sir.
    Subukan ko man aralin sir siguro pag nakita ko na hindi ko rin malalaman.
    Minamadali ni seller eh, napapaisip tuloy ako bakit ganung ka-rush tsaka maraming ESi na mas malinis at pormado na for swap din.
    Anyway mga sir, thanks for the insights.
    ganda pa nga... ganda ng tindig and mulhang fresh pa...
    mukhang grid 1570 o racing yung rim nya sir... not sure... but definitely not track r...
    Aug 2004
    Eclectic build. I approve of his choices. Though I'm not sure, I believe the SR18 has shorter intermediate gears, which should be great for performance. P11 axles should be a good fit... the P11 is a Primera, but an older one. That model is Sentra-sized and Sentra-width, so there should be little issue with them. I'd wish for an LSD, but if you're not dragging the car or tracking it, little need.
    Best thing to do would be to test drive to check mechanical condition... but for a straight swap, even if that thing has issues and even if it turns out it drinks gas like a mofo, that's a sweet swap.
    Apr 2009
    Nice. Thanks sir Niky.
    I'm sure you'd know if I told the axle-transmission specs.
    I'll meet up with him soon.
    I'm really not expecting good FC from something like that, but it's okay I'm used to 4 to 5 km/liter from my previous carb-fed Mazda.
    Not going to drag and track either.
    Just wanted an SR engine since then, because the red valve cover looks really cool.
    I'd still rather go for a SR20DE than the SR20VE....
    That's not Rota Track-R. Ano yan, Grid 2 na 17".
    IMO get a stock B13. Kahit siguro LEC. In good condition syempre, then do the swap yourself. Medj hassle pero mas sigurado ka.
    Apr 2009
    Got confused mga sir, eto pala yung nakita ko na pic with Track R and JDM bomb:
    A B14 is a better option for a more powerful engine. Stiffer body with the limited front suspension travel problem solved.
    Jun 2007
    Wheres the sentra located?
    You can ask for some sentra poeple especially that are expert with the sr20 engine to go with you. AFAIK the VE engines at WOT would give out 2 pulls. Its like the B16 of honda but for the sr20ve twice siya.
    Apr 2009
    Not really sure about its valve timing technology but it's NEO-VVL in a 2.0 engine so it should be more powerful than its smaller brother SR16VE.
    But considering it wasn't used locally, I can see why GH says the SR20DE is a better option - parts availability.
    The seller is really pushing for the deal despite my car's various issues. Makes me think I'll be in big trouble soon if something rare breaks down on me.
    For those interested for a steal deal, type "ricoboi" in Sulit and take the B13 ad. It is located in Lipa City.
    Yan definitely track r talaga.
    Apr 2008
    OK lang sayo na mas luma at mas masikip yung B13 sa ESi mo? At medyo nakakatakot din. SR20VE sa napakaliit at napakagaan na B13. Ano kaya pakiramdam kapag humahataw?
    Personally, I'd get a B14 with that engine. Meron naman eh. Tingnan mo Sulit ID 3712075. SR20VE Neo VVL din with P11 LSD tranny. O kaya Sulit ID 5287633, B14 with SR20DE naman.
    Quote Originally Posted by GTi View Post
    With a properly set up Sentra, it's quite stable. Even more stable then the Corollas of it's age if you ask me.
    Anyway, with any SR20 swap, i'd go with the advice to look into the wirings. In a lot of cases the engines don't perform to their full potential because of haphazard wiring. This can be fixed but you'll need time and patience to go over the wirings.
    Quote Originally Posted by isa1023 View Post
    Something will always break. Consider it's a used engine in that car with unknown history.
    Then if you consider to bring it to the race track, you can't push it hard because of fear of breaking something in the SR20VE that is harder to find than hen's teeth.
    Even my SR20DE had a few issues that took quite a while to fix due to the number of difference SR20DE variants.
    If you have enough traction, it's like Darth Vader pushing you into your driver's seat using the "force". Heck, it's the same with a B14 with tuned SR20DE.
    Apr 2008
    ^Haha~ 187hp pa naman yan, in a sub 1000kg car. I remember my uncle mentioning about the SiR he used to take on drag races. Its significantly larger than the B13 and has lesser power than the SR20VE. And yet it would feel as if the car would lift off the ground anytime at speeds in excess of 200km/h, as if the slightest error with the steering wheel would send it flying off. He'd said it was fast but highly unstable in high speeds due to lightness.
1995 Honda Civic ESi vs 1993 Nissan Sentra (B13) SR20VE NEO-VVL
