Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
    Sep 2010
    #21
    Quote Originally Posted by quiescent358 View Post
    malakas po ang 1.5 engine lalo pag akyatan
    Yes sir malakas naman ung Honda BR-V (compare to old diesels like Crosswind or Adventure) but observation ko lang na kelangan i-floor minsan ang gas pedal lalo pag akyatin ang kalsada at may sakay na 7pax + luggages.
    Same with our Honda City (Also have the same L15 engine) na pag akyatin ang kalsada, bitin sa torque compare sa Vios hehe.
    #22
    Quote Originally Posted by akosijhay View Post
    Yes sir malakas naman (compare to old diesels like Crosswind or Adventure) but observation ko lang na kelangan i-floor minsan ang gas pedal lalo pag akyatin ang kalsada at may sakay na 7pax + luggages.
    Kung bitin, then push harder on the accelerator. Peak torque for most gas-fed NA engines is at 4k rpm so if you want more push, then rev it to 4k rpm.
    Feb 2018
    #23
    yup... pero sandali lang yung 5K version ng FX... later pinalitan sya ng 7K (1.8)
    although naniniwala naman akong mas modern na engines ngayon, hence more power.
    Rush and Avanza are both RWD...
    (sorry, matanda na ako)
    same ba "takbong pogi" sa "drive mayaman" ?
    yung naka A/C ka pero bukas ang bintana...
    ano pong definition ng "takbong pogi? hehehe 60-90 kph?
    Apr 2008
    #24
    Agree. When I was in Sagada, super daming 90s FX. That's where all old Tamaraws go to die I guess. [emoji28]
    When I went hiking at Mount Ulap (chickened out for Mount Pulag [emoji28]) a few months ago, I had to take a habal habal FX at the end of the trail since jeepneys in the area were few and far in between. It had no aircon, no headliner and no carpeting and was the barest vehicle I have ever ridden that wasn't a jeepney. Apparently still runs great though. Driver said it used to be a mega taxi in MM before it aged out of service. Though it must be said that they usually convert the gas ones to diesel.
    Sent from my SM-G965N using Tapatalk
    Jul 2013
    #25
    Quote Originally Posted by GTi View Post
    Even the 7K EFI engine had less power than the current 1.5s. I think a little over 90hp? And torque is at similar levels. At sampuan ang sakay! They don't make 'em like that anymore...
    kaso manual yung FX... If I remember correctly, 2 & 3rd gear ng FX sobrang gamit na gamit, tapos yung RPM nya, madalas nasa 3,000-4,000 range pa palagi - compared sa 2C version na below 3,000 yung RPM
    ok lang sila sa province... di naman kasi sila naka aircon.
    Sep 2005
    #26
    CVT kasi sir.. pag ganon lagay mo sa S.
    Dec 2019
    #27
    Quote Originally Posted by coiter View Post
    FWD ang ecosport, brv, Tiggo at ZS 1.5L subcompact crossover SUVs that the TS mentioned. only exceptions are the rush and avanza. but yes, FWD is usually more fuel efficient than RWD.
    A bit off topic but does this concept hold true for hatchbacks like the Picanto, Aeon, Wigo, atbp? Because of being FWD?
    Quote Originally Posted by grss1982 View Post
    yes.. no drive train losses.
    Apr 2008
    #29
    I don't think there are any RWD econobox hatchbacks nowadays. But yes, with all other aspects being equal, the FWD should be more fuel efficient than the RWD mainly because there is no need for a driveshaft to transmit power from the engine in front to the wheels at the rear. When placed on a dyno, the FWD should also make more power because of lesser driveline power losses due to absence of said driveshaft.
    Mar 2018
    #30
    And no drive train noise as well [emoji3]
1.5L Gas Engines on MPV/SUVs
