Results 1 to 9 of 9
- Nov 2017
- 11
March 18th, 2019 02:24 PM #1Hi Guys, Need ko help nyo about sa issue ko sa car ko regarding High RPM pag naka Idle.
When I start the Vehicle Mamamatay, pressed the gas 3 times then start again mag start sys pero I need to press gas for 10 seconds.
after ma press ng 10 seconds parang galit na galit makina.
I've tried playing the A/F pero when I try to turn the Idle speed screw walang nangyayare.
Tried to play na din yung idle mixture screw hinigpitan ko ng kaunte, RPM goes down pero hirap mag start at pigil ang hatak.
Everytime na bumabyahe ako if naka loose ang Idle speed and Idle mixture screw ang bilis ng rpm ng makina.
Other issue on this is RPM goes high and low when the AC is on.
Carb was just newly overhaul.
Timing was set and tappets were tuned na din.
Toyota Corolla 1999 2e 12 valve
Sparkplug: NGK
Engine Oil: 10w40
Question is: May IAC ba ang ganitong unit? if meron yan ba ang makakasolve ng issue ko? Saan po located?
If hindi po ito ang sagot anu po ang dapat ko gawin?
- Jun 2005
- 3,774
March 18th, 2019 10:25 PM #2
March 19th, 2019 08:09 AM #3
May solenoid dyan na taga maintain ng idle speed. Baka lumuwag yung wire o sira na. Happened to my carb honda before.
- Nov 2017
- 11
March 19th, 2019 10:25 AM #4
- Nov 2017
- 11
March 19th, 2019 10:26 AM #5
- 52,731
March 19th, 2019 10:30 AM #6
- Jun 2005
- 3,774
March 19th, 2019 11:31 PM #7Carb problem. I think nakita na ng mekaniko problema and offered solution but you dont like the solution (or maybe mas alam mo problem).
Stating the obvious, may sira pa din kotse mo. Maybe its time to follow the mechanics advise? Ano ba daw papalitan?
Sent from my MI MAX 2 using Tapatalk
- Nov 2017
- 11
March 20th, 2019 10:33 AM #8
- Jun 2005
- 3,774
March 20th, 2019 02:48 PM #9
