You're still going to have the replacement vehicle (incase you decided to change) repaired for the similar quirks you're experiencing now with your Town Ace. Weigh the costs, if you'll be buying another vehicle, might as well go for the local ones, gives peace of mind and you don't have to pay to correct those minor inconviniences.
1. Add/replace insulation in the engine well, also probably the rubber seals starts to become useless, replace them- engine is under a seat and an amount of heat seeps thru
- window/door/ side mirror controls are on the right passenger side
- side mirrors are optimized for RHD driving
- gear shift doesnt lock up in its respective selectors
- wippers are set for RHD (so when raining a large spot on the upper left of the windscreen .. my side is left un swept)
- torque is on the weak side (270,000+ on the odometer)
2. I guess there is no fix for that, unless there is a local assembly which fits
3. Replace them with local counterparts
4. No idea on this
5. Could be retrofitted I guess, many JDM vehicles I saw natransfer na
6. Have you changed filters and fluids already? Delayed ba ang pag shift, if so then you may need to have your transmission overhauled.
Guesstimate cost is 40-60k with tranny overhaul already.
