Results 1 to 18 of 18
    Jul 2010
    Sir may tanong po ako... bibili kasi ako ng sasakayan 2nd hand... first time ko po bibili... kaso ako daw magpaparehistro ano ba dapat kong unang gawin bago bayaran ung sasakayan? gusto ko din humanap ng magassist sa pagrehistro at transfer of ownership...
    magkano kaya aabutin ng rehistro charade 2 dr 93 model registered 2008 pa...
    tsaka ano po ba dapat ko icheck sa sasakyan?
    ... maraming salamat...
    09173820621 / macaalaybryan*yahoo.com
    Jun 2008
    Quote Originally Posted by macaalaybryan View Post
    Wow! Daihatsu Charade, pwede to gawing project car sir!
    Anyway, before nyo po bayaran yung car:
    1) Double-check its papers with LTO if tama ba yung nakalagay sa OR at CR (to avoid if it's a 'hot car' or 'stolen' or may bad police record).
    2) Check the car's history for accident (if there's any). Hmm.. since it's last registration was 2008, may fine na po yan (not sure if it's Php 1,500.00).
    3) Yung Deed of Sale, papa-notary public nyo po yun, this is needed for Transfer of Ownership. I-mamacro etching din yung car for this to see if it's the same chassis number with that of the CR.
    As for the Car itself:
    1) Test drive the unit. Pakiramdaman for any 'kalampag' or unnecessary noise aside from the engine.
    2) Check for any leaks: Radiator hoses, coolant reservoir, etc.
    3) When test driving, let the steering wheel be on a 'free-will'.. observe if papaling sa kaliwa or kanan. Kung ganun, you may need to do wheel alignment.
    4) Observe the Engine Idling upon starting, driving and if pag naka-on ang aircon at pag naka-off. If erratic ang idling, you may want to check on the history of the carburetor.
    5) Observe for other engine noise like squeaking sound: check the timing belt tension and compressor, baka need na palitan ng bearing. This may occur when starting the engine, while driving, or pagnaka-on ang aircon
    6) Check the brake fluids and oil level ng engine
    7) Air filter if ok pa or dusty na baka need na palitan
    8) Electrical wirings for any burn-out wires and check fuses as well
    9) Check brakes (mag accelerate ka then step on the brakes agad if kakagat, baka you may need to replace brake pads or shoe)
    10) Pakiramdaman ang clutch and if pumapasok agad ang gears pag nag-sshift ka. Dapat less gritty sound or wala ka dapat marinig na gritty sound ng gears otherwise baka may bungi na yung isa sa mga gears sa transmission box
    Hope this little insights help you out sir! Good Day!
    Jul 2010
    thanks sir abet... this helps me a lot... ill let you know if successful transaction... need pala i notary yung deed... kala ko aabutin ng 10k gastos sa rehistro eh tagalna kasi di nakarehistro... but i will check sa lto sir... maraming salamat ulit sir...
    and salamat sa tsikot.com more power...
    Jun 2008
    No problem sir, your welcome po!
    Yes, need i-notarized ang deed of sale just like any public document, katibayan kasi yun na ikaw na ang may-ari ng nabili mong car. Yun bayad jan mura lang, pero depende sa mapuntahan mong notary public, yung iba nag-bbase sa total amount ng acquired vehicle den saka compute magkano ibabayad.
    Less than a thousand din po macro-etching, yung tira dun itabi mo narin for emission testing para sa rehistro.
    Then again, check the overall performance of the car's engine, wag mahiyang i-test drive at ask previous owner ano na history ng car Good Luck sir!
    Jun 2010
    yung deed of sale, wala ka nang problem doon, dapat yung owner nung charade ang magpapanotaryo noon.
    dahil sa registration, tawaran mo pa yung charade.
    ang masasabi ko sir, marami kang ipapaayos sigurado sa charade since old car na ito.
    why not get a Corolla small body or Lancer Itlog or Sentra LEC?
    Jul 2010
    sir nakita ko na ung sasakayan kaso wala ung bilog sa makina ano tawag dun? para saan ba yun sir? ung malaking bilog pagbukas ng hood...
    nagcheck ako parehistr sir eto breakdown nila...
    MVUC: 2,800 [kasi 2 years na daw di nairehistro 2009 tsaka 2010]
    LRF: 10
    Sticker: 50
    Computer: 170
    Change : 100
    Penalty: 700
    Insurance: 900
    Misc: 250
    Storage Fee: 45
    tama po ba yung mga price sir?
    thanks in advance...
    Jul 2010
    sir ben.. kung kaya lang talaga eh... kaso 60k fix lang talaga ang budget eh... first car din kasi... maraming salamat sir...
    Jun 2008
    tama si sir ben, mas maige kung sagot na ng seller yung pa-notaryo ng deed of sale para less hassle.
    hmm.. malaking bilog? baka you're referring to the air filter intake na nakapatong sa ibabaw ng carburetor? anyway, baka nagpalit ng aftermarket replacement parts yung owner ng car.
    for a budget of 60k and mag-ok ang deal, save up some extra cash for the replacements, like timing belt, oil filter, air filter, radiator coolant, change oil, brake fluid.. saka na yung aesthetics ng car
Need ADVICE SIR...
