Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Dec 2018
    Picking between crv 3rd gen and accent hatchback 2014 up. My budget is around 350-400k and activities are usually long drive. Ano kaya mas okay between the two when it comes to comfort, fuel efficiency, maintenance, and drive?
    Aug 2009
    comfort-subjective. May iba kasi yung comfort para sakanila is easy ingress/egress, some yung "liit' ng kotse. May iba naman comfort para sakanila yung ride quality, seats and etc. But i'll have to give this sa CRV
    fuel efficiency- accent by a long mile
    maintenance-parang same lang.
    drive-subjective din pero long drive sa accent ako.
    May 2019
    If it’s for a long (traffic) drive, I’ll go for the more fuel efficient one.
    i have a wigo, and i have innova. they have similar peso costs, when it comes to fuel.
    the innova (much bigger than wigo) is a more comfortable drive. i also feel safer in it, in the expressway.
    but i can squeeze the wigo into spaces built for tricycles.
    "what is my usual drive like?"
    Aug 2017
    Quote Originally Posted by trann123 View Post
    I owned a CRV gen3, and owns 10 Accent Diesels
    Comfort: Accent... Caveat, HB rear seats are not as comfortable to seat on vs Sedans (back rest angle is steep)
    Fuel efficiency : Accent, best out there
    Maintenance : Accent parts are cheaper
    Drive: Petrol engines are always better, despite the power Accent turbocharged engines gives you
    Dec 2019
    I've posted about this issue before on here about the battery/electrical warning light turning on and managed to get it fixed, but now it resurfaced after I secured the connection for the alternator (less than 50,000 km since it got replaced) which I found loose and almost unplugged for some reason, yet the car still ran properly both before and after I redid the connection. I've re-checked the run of the wires from the alternator to the battery and they are secure. I'm thinking of using electrical contact cleaner (like WD 40 Specialist Electrical Contact Cleaner) to see if it's just corrosion or debris since the contacts may have gotten wet in the monsoon rain a few days ago. I'll also be testing if the battery still charges properly. Would this be advisable or should I do something else?
    Quote Originally Posted by MasonLogan View Post
    alternator contacts? that rotating thing inside?
    i thought they're self-cleaning...
    but go ahead and tell us what happens.
    i could be wrong...
    good luck, po.
    we await follow-up.
    Aug 2017
    I always have a can of electronic cleaner (all brands, same effect). I've used it in just about anything that uses electricity. Most recently, my park and brake lights won't go off... Sprayed liberally to the under-dash fuse box... Wallah... Problem solved.
    The alternator contact cleaning might work, no harm trying. If it doesn't, maybe it is time to change the carbon sticks.
    Update us please
    Use that contact cleaner. Refit that connector several times as this will make the metal to metal contact better. Avoid pushing at an angle - she might say ouchy
    wala na bang gumagamit ng liha o kikil ngayon, to improve on electrical contacts ?
CRV 3rd gen or 2014 accent hb?
