Results 1 to 3 of 3
    Jul 2012
    What to look for?
    Suspension? Engine?
    I test drove a while ago, medjo mataas road noise but the engine was very torquey
    Malaki ba difference if i change the tires to normal ones? Ang tagtag talaga noong run flat tires
    What are the affordable bmw shops/mechanics where i can have it serviced?
    Jun 2006
    I'd go with the torquier and newer 520d. Check for the usual like suspension, if it was flooded, if all buttons work, if the engine emits smoke when you open the oil cap, if it doesn't overheat when driven hard (it never should), if the AC can make you shiver and numb, etc. the engine should sound good. One way to do that, is test a friend or someone's e60 diesel and compare with what you are intending to get.
    You probably can change to non-runflat tires but does it have a provision for a reserve tire,even just a donut (superthin spare)?
    How much are you getting the E60 diesel?
    Jan 2014
    I had for the newer diesel fed 5
    TS meron dito sa Maginhawa katabi ng kanto papasok sa UP Bliss
    dami nagpapagawa na BMW
2007 bmw 520d vs 2004 bmw 525i
