Results 1 to 6 of 6
- Jul 2011
- 4
July 24th, 2011 10:37 PM #1Hello just asking magandang combination ng amplifier at speaker! nag ccanvass aq ng alpine v12 MRV-f705 2k lang mhigit! merun na kase aqng buffle d q sure ang size qng 12 or 10. inch! d kahit d nmn masyadong boom boom ang 2nog! basta me kick na maaus! ano kyang possible n combination ng ganitong amps! me nakita aq! na kickercomp 2k! plus pwede na ba ito! low budget lang kase aq!! nga pla buffle q is ginaya daw sa JBL design na nasa loob ang speaker! d nkalabas!
maraming salamat po sa tulog
July 27th, 2011 02:03 AM #2
First of all, kindly refrain from using text speak. May full-sized keyboard kayo sa harap niyo, gamitin niyo naman. Hindi ito parang Blackberry lamang.
I'm not sure with the Alpine's V12 price since hindi na ako updated ngayon but V12 is a good starting point for anybody beginning to get into car audio. Stay away from the Kicker, at 2,000php, it's obviously a fake. At hindi ko maintindihan kung anong pinapagsabi mo sa "baffle". Hindi kita yun speaker cone? huh? There are only 3 types of baffles: IB, sealed, ported. There are others like isobaric but this are more advanced and harder-to-implement baffles. From what I can understand, your box is in this category?
From your budget, get a JBL GT5 and use a ported box for it. This wouldn't be SQ but you'll be able to play loudly compared to a sealed box.
July 27th, 2011 09:06 AM #3
[SIZE="4"]REMINDER: do not post messages in SMS/TXT shortcut format & grammar. Use proper sentenses and paragraph construction. If your posted message is hard to read, less people will read it & respond.
Read the RULES.
Ignorance is NOT an excuse.
Repeated offenses will lead to banning.[/SIZE]
- Jul 2011
- 4
July 27th, 2011 05:20 PM #4sir Sorry for the TXT mesage! what I mean is! sealed nga siguro yung type of box na yun! kasi yung position ng speaker is nasa loob sya ng box so bale hindi kita ang speaker.. pag nkalagay na sya sa box! merun syang takip! and for JBL speaker tanong ko lang po! soft po ba ang tunog nya? or mayroon po bang amplifier na me control for soft kick and punch kick? thanks po! sa pag reply? or any recommended na amplifier as of now!. and pag ported ba sir pasok ba dito yung ma bilog like cannon shape box! or oval camell back.. how about the setup for SQ! yung soft! kicks! ano po bang recommend nyo po thanks
July 28th, 2011 12:33 AM #5
Actually, both ported and sealed enclosures means that you can't see the magnet (unless you made one side of the box out of transparent material like a plexiglass) but you can still see the woofer's cone.
The JBL GT5 is a very well known entry-level subwoofer so there's no question about its quality. The "tunog" can easily be fixed with proper tuning. Most "kicks" (most evident is from the kick drum) we feel are actually from the midbass rather than the subwoofer (you feel this around 80-100hz) assuming you cut your low-mid transition to around 80hz (typical cutoff)
Yun "bilog like ma-blog like cannon" is a ported box. Always remember to deaden your doors. I feel you'll have a lot of improvement just from that alone.
- Jul 2011
- 4
July 29th, 2011 02:36 PM #6Sir! thank you! for helping! sharing my baffle! nasa loob po tlga ang whole speaker! merun yang parang door! doon mo papasok yung speaker at! sasarahan mo n lang pag nkakabit na ang speaker!! thank you
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
