Results 1 to 10 of 28
October 29th, 2003 12:15 PM #1
Wurth® Sound Deadening Panels
(6 Sheets 10in. x 22in. each) - Php 2,600
Reduce Road Noise!
Wurth sound deadening panels are a heavy duty bitumen based material with a polypropylene covering. Wurth sound deadening panels reduce noise within the car that are due to resonating body panels such as floors, doors etc. Panels are adhesive backed for easy installation.
Usage Tips For Best Results:
*Surface must be clean, free from grease and dry.
*Can be applied to primed and painted metal surfaces.
*Both surface and product must be warmed to 68 degrees or higher.
October 29th, 2003 05:51 PM #2
boss theveed,
available ba yan sa big bert's? do you guys install? TIA
October 29th, 2003 07:43 PM #3
Parang yan din yata yung nakakabit sa akin... I think I'm having amnesia... errrrrr
- Apr 2003
- 526
October 29th, 2003 08:00 PM #4how much of that would you need to cover the entire floor area for a sedan?
pasensya na ah, tinatamad akong mag guesstimate
October 29th, 2003 09:30 PM #6
its installed sa insides of the door panels, ceiling panel, and floor panel.
you have to take out the door sidings, carpet, seats, and ceiling material in order to install it.
in fact, 2-stage ang dapat: 1) apply the bitumin material to all the panels mentioned above; then, 2) apply the specially made adhesive foam on top of the bitumin material.
October 29th, 2003 09:35 PM #7
e di tanggal lahat? advisable ba ito sa mga brand new cars? parang sayang ata yung pagkaka install sa mga carpet, ceiling, and other panels ng factory kung brand new pa.
Signature
October 30th, 2003 10:15 AM #8
Meron ding ganyan akong nakita sa ACE Hardware ata o sa SM WORKSHOP, pero its for the HOOD.... noise reduction mat.... less than 2K, lesser hassle pag kabit! Question: Same effect din ba yun o mas effective yung sa flooring and door sidings?
October 31st, 2003 05:36 PM #9Originally posted by boybi
November 1st, 2003 01:36 PM #10
siguro mas ok ito kung more than 4 or 5 yrs na yung car, para sabay palinis na rin yung mga nasa loob. since kung brand new naman hindi pa naman maingay. nakakahinayang din kasi pagalaw kung bago.
Signature
