Results 1 to 10 of 13
- Feb 2007
- 48
August 3rd, 2007 10:39 AM #1kng lagyan mu ng mas malaking ampir ung amplifier anu mangyari? bibigay ba ng malaking volt?
August 3rd, 2007 10:49 AM #2
Nope, it is a safety feature. If there is a surge of voltage that goes thru the amplifier, more than it is designed to take, then it is the fuse's job to cut off the power supply so that the amplifier won't be damaged.
Think of it this way, it is like a circuit breaker for the amplifier.
August 3rd, 2007 10:51 AM #3
The fuse is for protection of your electricals outside of the Amp.
Kung ang amp mo ay gumagamit ng 10 Amp na fuse, wag papalitan ng mas mataas na fuse dahil baka ma baliwala ang protection na binibigay ng fuse.
Ang fuse ay may current rating na puwedeng dumaan sa kanya. pag lumagpas ka rito iyong fusible material nya ay matutunaw and then mapuputol.
Tsikot Member Rank 4
- Jun 2006
- 2,605
August 3rd, 2007 10:56 AM #4The fuse is there to protect your amp. Its designed to be the weak link in the electrical system and blow in case of short circuit or electrical problems. Simplest explanation is its there to sacrifice itself and thus saving your amp from damage.
Don't change it to a higher rated fuse. It might not blow and your amp will be toast. :electricf:Last edited by userfriendly; August 3rd, 2007 at 02:51 PM.
August 3rd, 2007 11:06 AM #5
wala pang gumagamit ng automatic circuit-breaker sa mga auto,e...kaya fuse lang.. bakit kaya????
- Jun 2006
- 2,605
August 3rd, 2007 03:06 PM #7I know they also sell circuit breakers for cars. Saw some a long time ago. It is more expensive than fuses.
BTW, make sure you install a properly rated fuse or breaker within 18 inches of your battery. Its to protect your car incase your power cable going to your amp gets damaged.Last edited by userfriendly; August 3rd, 2007 at 03:09 PM.
BANNED BANNED BANNED
- 3,790
August 3rd, 2007 06:48 PM #8merun na akong nakita na small versions ng circuit breakers...ga botones lang...parang P30-50 a piece .... hindi ko lang alam kung anong voltage and amperage ang rating nun.
- Feb 2007
- 48
August 4th, 2007 01:31 AM #9ah ok. buti na nga d ko pinalitan ung fuse! akala ko bibigay ng 14volts. paanu mu bibigyan ng 14volts ung amp mo? kasi sa specs ng amp kng bibigyan mu ng 14volts lalakas ung amp, tataas ung rms. paanu yun?
- Jun 2006
- 2,605
August 4th, 2007 10:56 AM #10
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
