Results 21 to 40 of 45
    sir andeyyy, im currently using an orion cobalt, 260w yung rating niya.. 2ch for my subs
    iba pa ba yung 225?
    tkz111,
    I agree with andeyyy... it really depends on the resistance capacity of your amp and how you wire the L7. Check the link below to know more about the Orion 225 HCCA - medyo luma yung article but it's worth reading!
    http://www.ofsoundmind.com/osm/auxi/elect4.html :mrgreen:
    ive heard about these cheater amps... hehe so currently i have an orion cobalt rated at 260/2 .. can i work with this?
    wow.oks yan.
    mga gurus, pano kong i wi wire tong orion ko to make it power an L7?
    ilang channel ba yung cobalt mo na amp? is it 4 channels? am not sure kung bridgeable....pero if it is bridgeable....go ahead......it gives your speakers more punch......pero if you can afford......try using Rockford Fosgate 1000.1 amps......be it two channel or one channel lang.......it would really bring out the peak power output ng L7's.......just like how I actually felt and heard in the last Transport Show sa megamall last time.......
    rf 1000.1 amps talaga balak ko eh, how much do these run here sa pinas? :D
    2 channel yung cobalt ko..
    but i have a bigger problem at hand..
    kasi i had my car repainted, so total stripdown, everything in the car was taken out.. eh hindi ko alam kung anong nangyari, at hindi gumagana subs ko nung binalik sa akin, so i tried to re wire it nalang myself, but then sobrang sabog nung subs! (2 ryan audio 12") :oops:
    rf 1000.1 amps run from 20,000 Php up.......
    reagarding your subs.....that really is a big problem......I have also brought my van to a 3-star motorshop to have it re-painted.....so before I brought it there....I had all my sound system set-up taken out.......my only advantage is.....kahit pagbali-baligtarin mo ang system ko.....I know how to put it back in order......
    why not try to analyze your system...what might be the main problem that causes your subs to make unnecessary noise......
    i know my system eh, pero the prob is after i re wired everything, sabog!
    its not noise eh, parang sobrang hindi kaya ng subs? or something kasi even at LOW volumes, nag c clip yung subs.. akala ko na reverse ko lang yung polarity at first, pero hindi rin eh..
    may tama na ba yung mga subs mo? check your power supply......or baka naman nabagsak ang subs mo.........
    i dont think nabagsak eh..
    what about the power supply? yung subs lang talaga eh
    my seps are fine..
    hmm..
    wala pa namang tama subs ko
    are your subs enclosed? check mo.....then check the amp that runs the subs.....baka dun nanggagaling ang clipping....
    naayos ko na!! :D
    (*#&$*(&#$&* electrician mali mali saksak ng mga wire, hehe i was looking at a + wire na naka connect sa ground socket! kainis! hahaha oh well thanks sir nielsen!
    just as i suspected.....good thing walang nasira.....meron ba? better check on it thoroughly........:D
    nah wala nasira kasi hindi rin nai saksak mabuti yung power, so at first di gumagana yung subs..... nakita ko rin agad yung problema when i checked kanina... sayang lang nga nilabas nila lahat ng wires malinis na dati yun eh :oops: oh well! salamat ulit
    tkz,
    R you sure you want the L7s? If you were impressed by cars in solobarics in the carshow at megamall, some of them are not actually running L7s. The L7s are actually the ones with the silver cones (not the tribal grill which can be painted silver or any other color u want). The L5s are the ones that have black cones. They are less power demanding and the amp required by these could be more suitable to your budget. If you're not planning to join a SPL drag, the L5 would be ok. Yayanig ka na rin dun! :lol::lol::lol:
    Check out the pix at theveed's pbase...
    http://www.pbase.com/theveed/2002_motorshow&page=4
    Sir theveed, pa link lang po...
    Like your pix! :lol:
    Quote Originally Posted by Zhero
    tkz,
    Correct!!! I was waiting for someone to bring this up......that is the main difference between those two subs.......thanx Zhero...:D
    neilsen, tkz
    the pix link above is from the motorshow c/o theveed. i didn't bring a cam sa megamall and m still organizing my own pix gallery.
    correct me if I'm wrong, i think the solobarics in the pix are just being powered by 4ch v12 with 1-2 bridged for 1st sub and 3-4 same for the 2nd sub.
    Thanks Sir Moderator :lol:
    wait wait...
    ung L5 UNG BLACK!? L7 UNG SILVER!?hhhmmmmmmmmm.......
    let us check that agaiN........
    the L7's
    the L5's
what amp?
