Results 11 to 20 of 25
    Apr 2006
    oo nga pala! my apologies.. old style abacus ang ginagamit ko kasi..
    baka nga star screws yan..
    hehe ok lang. not offended. mas gusto ko nga when people see i have an old vehicle pero na-aalagaan pa rin.
    ganito ba sir?
    e di ganito need mo
    TORX ang tawag dyan. yung iba pa may pin sa gitna lalo na yung mga made in France na appliances.
    so need mo Torx driver na may butas
    meron nyan sa handyman at ace, green ang color. yung ordinary hex bit red ang color.
    Quote Originally Posted by wewoy_romero View Post
    Yung katulad sa link ni oj88 ang iniisip ko if putol na yung connection sa antenna ko. Malakas talaga kutob ko yun ang culprit. Are those types of antenna good?
    i have that kind of antenna with our L300 versa van installed i think 9yrs ago pa yata. it seems the OEM telescopic antenna didn't work that much with my new after market HU so that's why i bought that so called powered/boosted one. but nothing had changed, FM radio sounds garbled still. i play CDs most of the time anyways and i didn't bothered to buy another antenna until the van was sold.
    Apr 2006
    *yebo
    6 sides siya so dapat hex screws should work. pero yung bottom part niya parang curved and shallow (dunno kung dahil na rin sa pagkaluma) that's why the hex screws won't "bite". i'll post a picture when i get the chance.
    *benchman
    thanks for the info. so i think mas ok na i-troubleshoot na lang yung stock antenna.
    may improvement naman ang fm reception from my old HU. pero minsan may static lang talaga at nawawala ang signal. can't help but compare it with our other vehicle (civic vti with a motorized antenna and stock HU) na malinaw reception even sa parking.
    Actually curious ako if antenna nga ba may tama or may nagbago sa modulation ng mga FM stations sa Manila?
    Was in the same dilemma 2 months back. Humina yung sagap so I thought antenna rin. Chineck ko naman yung wires gamit multimeter, buo naman. Bumili na rin ako ng booster saka pampalit na antenna, ganoon pa rin. May hissing noise talaga habang gumagalaw, pero malinaw naman pag steady lang ang sasakyan. Then a few days passed and scheduled na for hilamos yung sasakyan ko, so nakigamit muna ako sa iba. Pag-tune ko sa mga usual stations sa ibang sasakyan ganoon din. In the end bluetooth + Spotify na lang muna tuloy ako hehe
    sabagay meron nga ibang fm stations na humina. must be the taller buildings causing interference.
    Apr 2006
    Eto yung screws ng antenna for crv gen1
    http://i383.photobucket.com/albums/o...5_140855_2.jpg
    ...isn't that a torx screw?
    but it seems, eyeballing it.. you can also use an ordinary flat-blade screwdriver of correct size.. just be careful the outer edges do not scratch too much the antenna cover..
    torx yan sir.
    ^this, actually may sumpong din yun radyo ko minsan. hihina,,,, lalakas/mas claro. experiment sana and i tried looking for a much longer or higher gain antenna yun screw type kaso wala ako makita na kasukat nung thread ng OEM ng hilux.
Weak fm reception
