Results 51 to 60 of 62
August 2nd, 2016 12:03 PM #51
sir dalhin mo lang sa magaling na technician may paraan sila dyan. meron silang nilalagay na sariling switch parang bypass yun. if you live close to the south(Binan) dalhin mo kay BP audio. mga 30 minutes job lang yan.
Sent from my GT-I9300 using Tsikot Forums mobile app
August 2nd, 2016 12:08 PM #52
- Apr 2010
- 742
August 2nd, 2016 12:28 PM #53wanted to do it myself sana para matuto rin. may nakita na akong link dito sa Tsikot, yung green wire daw pero wala kasing wire pinouts yung radio sa body and sa manual nya so i cannot be sure: Video Shuts-off when vehicle starts moving. kung binaklas ko yung panels, mga magkano sisingilin nila?
Image says:
Caution: Driver is prohibited by law from viewing a video signal on any in-dash monitor while the vehicle is in motion
Working sya pag naka Park mode and/or handbrake is up (will double check later) but outside of Park, the message appears. Sound is unhampered though. Wala akong external displays as of the moment aside sa head unit.
August 2nd, 2016 12:40 PM #54
disclaimer: i only use it if i have a passenger, otherwise, i am on radio/spotify mode.
not sure with your case bro.... it could either be on your connections though. yung sa akin kasi simple lang ang connection. power is tapped sa HU din, antenna is at the back of the car.
- Mar 2004
- 85
August 2nd, 2016 06:22 PM #55Kung gusto nyong malinis ang installation at nakatago mga wires sa ilalim ng dash pwede kayo gumamit ng fuse tap circuit adder. Tapos kabit nyo sa spare na cigarette lighter plug. Mas malinis tignan kasi wala nang naka kabit na 12V adapter dun sa stock na cigarette lighter plug.
- Apr 2010
- 742
August 3rd, 2016 01:37 PM #56I hijacked the thread already that is supposed to be for head units with ISDB-T capability, pero dito lang kasi yung may digibox discussion
An update to my issue, handbrake-activated yung video lock - whether naka Drive or Park basta nakababa yung handbrake, video wont be displayed sa head unit. Am not sure kung titirahin ko ba sa handbrake switch or sa headunit, wala akong pinouts to begin with and walang manuals online regarding its schematic
I assume this is an AVT unit, with Toyota part number 86120-YZA95
August 3rd, 2016 01:58 PM #57
- Jan 2003
- 53
August 3rd, 2016 02:04 PM #58
look for the PINK wire from the head unit. isolate and cut. tap to ground/ negative (the PINK wire coming out the head unit). the stereo body will do. you may put an on-off switch if you like. you can now watch video/ tv without having to stop.... but always keep your eyes on the road
- Apr 2010
- 742
August 3rd, 2016 02:05 PM #59yes stock. as i've researched lahat ng video-capable head units has a function not to display the video when outside of park/handbrake, pero you or your installer did not installed it probably
sige i will check probably later or this weekend. iisa lang ba yung pink line dun? on youtube videos, pink or green kalimitan na gina-ground nila. the head unit is stock from a previous-gen Innova
Firefox browser - :wonder: may error kapag mag attached ako ng piktyur sa computer ko insert image...
Problems with viewing Tsikot on non-Chromium...
