Page 5 of 6 FirstFirst 123456 LastLast
Results 81 to 100 of 106
    Jan 2009
    #81
    How do you supply power to your 12V TV Plus units?
    1. Directly from the car's 12VDC source (ie. Accessory line, direct from the battery, etc.)?
    2. 12VDC to 220VAC power inverter then using the TV Plus' 220VAC to 12VDC power adapter?
    3. 12V-12V, DC-DC converter/regulator?
    Apr 2010
    #82
    tap from 12V accessory line
    Sep 2018
    #83
    newbie pa dito. new owner lang din ng montero gls 2018. anyone has an idea kung pwede ang tv plus sa montero 2018 stock headunit? salamat ng marami.
    Sep 2006
    #84
    Quote Originally Posted by jaypee10 View Post
    tingnan mo muna sa manual ng stereo kung may audio video.AV in or AV aux.kung wala..sound lang talaga mapapagana mo dyan.
    Gumana sa mu-x ko. Hindi lang dapat madiin ang pagkabit sa avin
    Aug 2014
    #85
    UPDATE for this problem.
    Issue is solved.. i repeat solved haha using the P414 noise isolator they sell sa Lazada. Static on the audio completely GONE!
    For the link of the item ---> https://www.lazada.com.ph/products/f...4xHes&search=1
    Quote Originally Posted by xgamerx3 View Post
    nainstall nyo na po ba "Car 12V Voltage Regulator Noise Filter Stabilizer"
    gumagana na po ba ng maayos yung tvplus nyo ?
    wla na po ba humming sound?
    pareho po kasi tyo ng prob.
    hnd po head unit ang problem.
    power source po tlga ang prob. kasi sinubukan ko isaksak sa outlet ng bahay using extension cord at yung power adaptor ng mismong tvplus na ksma sa box. wlang humming sound.
    nag huhum lng pag sinaksak ko na sa cig lighter ko
    #86
    Quote Originally Posted by page7fordoddie View Post
    san end mo kinabit bro?
    from tv box to HU audio input ba?
    edit: nagload na lazada app hehehe
    sakin kasi ferrite core lang gamit ko ..
    Jul 2019
    #87
    Mga Mam/Sir.. ask ko Lng bat po pag umaandar ung saaskyan (mazda 2 Gen3), nawawaLa signal ng TV plus.. then ung antenna q nakalagay sa Loob sa may kanang bahagi ng dashboard po sa harap.. any solutions po..
    #88
    Quote Originally Posted by Virenesis View Post
    diba may safety feature nga yan na connected sa handbrake? hanggat di sya engaged wala lalabas sa screen
    #89
    oo nga.
    but every other owner knows, there are easy ways to go around that safety feature. they do not advertise, but... the casa folks and some banawe folks know how.
    me? dunno... i don't have video in the car. AM radio lang.. dzmm.
    Jan 2009
    #90
    It's likely a reception issue. There are many factors that can affect it but I've narrowed it down to three things...
    1. Your distance to the TV stations
    2. Antenna type, orientation and/or placement
    3. RF interference
    4. If you have metallic window tint/film
    #1, 3, and 4 are self-explanatory.
    TV receivers, whether analog or digital, if properly designed for vehicles, usually have powered/amplified/boosted and/or diversity antennas. The TV Plus box can power an active antenna but it's not designed for diversity reception.
    The best you can do is mount the antenna on the roof.
    Aug 2019
    #91
    If your head unit is android based, you can buy the new ABS TV Plus Go dongle at P799 and a separate microusb female to USB type A male adaptor (available at Lazada). Plug it in your headunit's USB port, install TV Plus Go app from playstore. That's it. Touch control, no wiring hassle, no audio issues and no need to bypass brake wire.
    Here's the demo:
    ABS CBN TV PLUS GO WORKING ON ANDROID HEADUNIT (100% Touch Control) - YouTube
    Aug 2019
    #92
    oo nga.
    There's a ground wire connecting from the headunit to the parking brake switch (usually located at the base of the hand brake). Cut that connection in the hand brake switch then connect it directly to any of your car's ground. Bypassed!
    Aug 2019
    #93
    kahit ba tumatakbo ang car malinaw pa din ba ang reception sa tv.
    #94
    Quote Originally Posted by wenz_vios 1.3 x View Post
    yes
    digital ang broadcast/signal. so like HDMI, it either works or not
    unlike analog na pag mahina lumalabo, pag malakas signal malinaw
    Aug 2019
    #95
    yes
    anong brand nang tv box maganda. ayus ba ang abs cbn tv box. plan kasi mag install gusto ni misis para daw pag hatid sundo sa kids may mapanoud din daw. thanks
    #96
    IMO pinaka OK parin yun abscbn box
    yun nabili kong cheap digibox cheaply built eh
    kung naka android headunit ka sana ok yung abscbn GO
    Apr 2014
    #97
    Magdala na lang ng tablet sa kotse.
    Ilang oras ba ang byahe? Baka di pa tapos commercial, nakauwi na.
    Edit. May tvplus go na pala. For tablet and cp.
    #98
    Quote Originally Posted by chronicle View Post
    naalala ko nun naglagay ako nyan noon sa vios
    isang beses ko lang nagamit ng matagal tagal (like 30 minutes yata IIRC) while waiting sa market mall, pangit ng mga palabas sa broadcast; ended up using my mobile phone nalang watching youtube LOL
    tapos while driving, kinukulit ko passengers ko manood habang nasa long drive .. deadma sila hahaha
    #99
    tanikalang ginto and wowowin.
    addicting.
    but only if the screen is big.
    Apr 2014
    #100
    Nakakahilo din kasi manood habang gumagalaw ang sasakyan kaya ayaw ng passengers mo.
    Imo, not sulit ang tvplus sa kotse.
    Madalas mapapanood mo, mga kabaduyan. Maiinis ka lang. Heheh
    Mas chill magpatugtog na lang ng mga favorite songs.
TV Plus Car Installation
