Quote Originally Posted by ILuvDetailing
Targa is not bad for budget setups, but Crystal sounds better for me, it also depends on the tuning.
I'd go with the V12, specially with the newer models comming out with good enough power to provide some ommphh... but if you can source a 2nd hand amp like an alpine, mtx, infinity, etc. that would be better...
Check the amp kit. It should have a pair of RCA, ground wire, power cable, terminals, remote wire, fuse, fuse holder. you can use the your 6 x 9s if you can tune it so that only lows will come out much better.
if your concerned about space go sealed.
newer amplifiers already have built in crossovers... some older model amps don't you have to check this when buying a 2nd hand amp... do a searc here, it has been discussed many times.
Can I achieve both SQ and SP at the same time or atleast balance both?
I asked the person there regarding Targa - Japan tech, made in Philippines, components are from China... So Targa is ok?
Regarding the amp, so using fake Alpine V12 is ok? CHoices as per your advice: V12 or F4100? Panget ba yun Fenton, base on your exp.?
What do ineed to check when buying 2nd-hand amp? 1KW ok na yuN?
What's the difference between sealed and ported aside from space consumption? How about sound quality? Where should it be placed? SHould it be facing front (papuntang driver), back (palabas ng trunk), or a specific angle?
Meron pa sinasabi sakin gapang paloob or palabas, what's that?
Btw, thanks for ur tips hehehe
