Results 1 to 10 of 30
- Jan 2018
- 23
January 30th, 2018 07:26 AM #1good day po ulit, ano po pwde gawin if yung stock HU walang RCA port? planning to install amplifier for seps and coaxial po eh. thanks.
January 30th, 2018 08:49 AM #3
January 30th, 2018 09:16 AM #4
Since mag upgrade ka ng sound setup mo, baka yang current HU mo ay pangit na talaga. Bili ka ng mas maganda. Yung may maayos na EQ and higher wattage.
Typically pag nag uupgrade ng audio setup HU/separates ang inuuna.Last edited by robot.sonic; January 30th, 2018 at 09:18 AM.
- Jan 2018
- 23
January 30th, 2018 12:00 PM #5
- Feb 2017
- 141
March 4th, 2018 04:01 PM #6
- Nov 2009
- 3
March 22nd, 2018 10:24 PM #7Sayang lang gastos for the converter, P450 din tapos destorted sound, before buying your amps or speakers, consider upgrading your HU first. Just my opinion
March 23rd, 2018 02:21 AM #8
Kung basic upgrade lang you dont need to spend too much na. Pwede na yang stock HU mo. As what Zero3 said bili ka LOC(line output converter). Or bili ka amp that could accept high level inputs or amps that has internal LOC like the pioneer GM series class D amps.
Hindi sayang ang gastos sa LOC. actually that is the wise route kung basic upgrade lang hanap mo. No need to spend so much on buying a new HU. Ganyan ginawa ko dahil ang HU ko ay di basta basta palitan dahil maraming controls and features ng sasakyan ay integrated sa HU. Also magiging distorted lang ang sound ng speakers if you push your drivers to hard to a point of extreme na ang excursion. Kahit palitan mo HU ng mamahalin magiging distorted pa rin tunog nyan yan pag sobra sobra yung volume. Tune/level match your amp properly.
March 23rd, 2018 11:46 AM #9
To me, last resort ang LOC. I'm no audiophile but I do appreciate good clarity and detail.
But it is your car. However, do note that not all LOCs are equal. There are quality LCOs (active) and there are crap ones. The cheaper ones can add 'color' to your music and you end up losing some details and/or gaining distortion and noise. But if you have to spend for a quality LOC, might as well change the HU instead. Though subjective, many decent aftermarket HUs aren't at all expensive.
The only reason you'd want to keep the OEM HU is when it is fully and deeply integrated with the car (ie. Part of the info-center screen). On the Innova, it is still modular and you only lose the steering controls, at worst.Last edited by oj88; March 23rd, 2018 at 11:49 AM.
March 23rd, 2018 02:59 PM #10
I'm no audiophile and an expert either, I just love a good music and do my own installs. People sometimes tend to forget when giving advice about audio gears if kaya ba ng budget nung nag tatanong ang suggestions nila. Parang you are shooting them down na kahit basic upgrade lang hanap nila. As what the experts have said, sa car audio it will always be subjective kung ano maganda. For some even just changing the front seps using the stock HU is ok na but for others they cant appreciate anything less than gears with dsp on 3way active setup. Problem din is yung TS di nag indicate ng budget.
soy-based wire insulation. 1. cheaper than the petroleum-based plastic insulation. 2....
BYD Philippines
