Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
    Feb 2009
    #21
    Quote Originally Posted by archie123456789 View Post
    it depends sa how you want your sounds to put out high, low, and mid. sa amp pwede mo kalikutin yung knobs and attain the sound you want.
    kung gusto mo hangang labas tunog ng subs... ano muna model nung subs? ano amp? saan facing yung sub, facing sa loob or the other way around?
    kung medyo low to mid end level type of subs and amps, hindi talaga maririnig gaano sa labas. L7 pa rin nagpapayanig ng mundo ko sa subs . although, ok din digital design sa bayo.
    actually mejo max na ung bass level sa amps ko, basta kinakalikot ko lang un, ndi ko nman kabisado ung mga un.. hehehe! anyways my subs is jbl GTO1514 and v12 amp 2000w, nka-face ung subs paloob pra pag binaba ko ung sandalan ng chair malakas ung bayo.. gs2 ko sana maging kcng lakas ng mga SUV ung boom ng kotse ko khit lancer lang.. hehe!
    question, anu ung meaning nung dual xka single voice coil? sa lakas ba un ng boses namaririnig sa subs or sa lakas ng boom? sorry newbie lang po.. :D
    Nov 2007
    #22
    with the system that your putting in, 60% volume is easy... just make sure magaling yung titira ng tono and set up and your fine. since your seps and amp are branded, i assume budget is not a problem. get the slim type subs and place it under the seats just to have that complete sound of sound quality.
    hth
    Sir I forgot to write that I already have an amplified subwoofer (AVT ISW-90). Is this good enough or should I change it?
    #23
    Quote Originally Posted by eminem015 View Post
    sir, kung naka amp ka, there should be no voice sa subs unless mala ray langit boses ng singer.
    voice coils... it just give you more options on how to wire the system. mas ok dual voice kung SPL gusto mo attain. more boom boom kasi sa 2 ohms rather than 6 ohms straight.
    Quote Originally Posted by Outcast View Post
    [/FONT] Sir I forgot to write that I already have an amplified subwoofer (AVT ISW-90). Is this good enough or should I change it?
    sir it all depends on how satisfied you are sa subs. kung ok na tunog for you, then ok na yung avt. pero as i understand it, its a built in amp sa subs, right? if so iba pa rin yung stand alone na subs that is externally powered by a good amp.
    if hindi pa satified, then go boston acoustics or JL audio. mas matigas yung bayo nito for your jazz/rock listening experience.
    hth
    Feb 2009
    #24
    ahh.. nweiz, how would i know if mine is a dual coil or not? panu malalaman sa itsura ng subs?
    #25
    may mali sa last post ko, its supposed to be 4 ohms not 6... hehe
    well malalaman mo kung DVC kung 2 sets of speaker connection meron yung subs. you have to open the enclosure or look at the box para malaman.
SQ without a subwoofer?
